Rate-Select is set to high on all devices (FEC-Mode is set to auto)
It’s the same on all interfaces - and no matter what I do…
- CRS326 here: 6GBit/s with the bandwidth Tester
- CRS518 there: 100MBit/s
awful.
I have to append that we’re using single mode SFPs for the 100G (we have single mode cabling). I have not seen any package drops…
status: link-ok
auto-negotiation: disabled
rate: 100Gbps
full-duplex: yes
tx-flow-control: yes
rx-flow-control: yes
fec: off
supported: 10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full,
1G-baseX,2.5G-baseT,2.5G-baseX,5G-baseT,10G-baseT,10G-baseSR-LR,10G-baseCR,40G-baseSR4-LR4,
40G-baseCR4,25G-baseSR-LR,25G-baseCR,50G-baseSR2-LR2,50G-baseCR2,100G-baseSR4-LR4,
100G-baseCR4
sfp-supported: 1G-baseX,10G-baseSR-LR,25G-baseSR-LR,100G-baseSR4-LR4
sfp-module-present: yes
sfp-type: QSFP28/QSFP56
sfp-connector-type: LC
sfp-link-length-sm: 10km
sfp-vendor-name: FS
sfp-vendor-part-number: QSFP28-LR4-100G
sfp-vendor-revision: 01
sfp-vendor-serial: G2311058537
sfp-manufacturing-date: 20231123
sfp-wavelength: 1310nm
sfp-temperature: 44C
sfp-supply-voltage: 3.272V
sfp-tx-bias-current: 56mA
sfp-tx-power: 0.614dBm
sfp-rx-power: 0.768dBm
eeprom-checksum: good
eeprom: 0000: 11 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 … …
0010: 00 00 00 00 00 00 2c 9d 00 00 7f d0 00 00 00 00 …,. …
0020: 00 00 2e a1 2d 89 2b 02 2a f7 6e 19 6b 9d 6e 89 …-.+. *.n.k.n.
0030: 6e 7e 2d 00 36 91 2f a6 32 8b 00 00 00 00 00 00 n~-.6./. 2…
0040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 … …
0060: 00 00 ff 00 00 00 00 00 00 00 1f 00 00 00 00 00 … …
0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 … …
0080: 11 ce 07 80 00 00 00 00 00 00 00 03 ff 02 0a 00 … …
0090: 00 00 00 64 46 53 20 20 20 20 20 20 20 20 20 20 …dFS
The 25GB DA Cables look like this:
status: link-ok
rate: 25Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
fec: off
1G-baseT-full,1G-baseX,2.5G-baseT,2.5G-baseX,5G-baseT,10G-baseT,10G-baseSR-LR,
10G-baseCR,25G-baseSR-LR,25G-baseCR
sfp-supported: 1G-baseT-full,1G-baseX,2.5G-baseT,2.5G-baseX,5G-baseT,10G-baseCR,25G-baseCR
sfp-rx-loss: no
sfp-tx-fault: no
sfp-type: SFP/SFP+/SFP28/SFP56
sfp-connector-type: copper-pigtail
sfp-link-length-copper-active-om4: 1m
sfp-vendor-name: FS
sfp-vendor-part-number: S28-PC01
sfp-vendor-revision: A
sfp-vendor-serial: F2230383968-2
sfp-manufacturing-date: 24-01-25
sfp-dwdm-channel-spacing: 13Ghz
eeprom: 0000: 03 04 21 00 00 00 00 00 04 00 00 00 ff 00 00 00 ..!.. …
0010: 00 00 01 00 46 53 20 20 20 20 20 20 20 20 20 20 …FS
0020: 20 20 20 20 0d 78 a7 14 53 32 38 2d 50 43 30 31 .x.. S28-PC01
0030: 20 20 20 20 20 20 20 20 41 20 20 20 00 00 00 44 A …D
0040: 00 00 68 00 46 32 32 33 30 33 38 33 39 36 38 2d ..h.F223 0383968-
0050: 32 20 20 20 32 34 30 31 32 35 20 20 00 00 00 e7 2 2401 25 …
0060: 80 00 1b 82 86 c2 8a 85 9b c4 bf 45 13 73 85 f1 … …E.s..
0070: 7f a5 d2 00 00 00 00 00 00 00 00 00 93 34 e9 f3 … …4..
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 … …
EDIT:
are the low bandwidths on the SFP+ ports or on the QSFP (100G) ports? because on the 100G links there might be an improvement if you configure
FEC on the CRS and the other switch (FEC must be the same on both link ends!)
No, they are not. But I’m anyways not talking about 10 or 15GBit - I am talking about MEGABITS. We currently have 300 MBit/sec throughput. Not even one Gigabit.
Something is completely off - and I have no clue what it is at the moment. No matter what ports I use… 25GBit/s DAC, 10Gbit/s SFPs, 10GBit/s DAC or 100GBit/s QSFP25 - the CPU load goes up like crazy (and yes, the system shows the HW Offload is on) but it’s like having a 20 year old cablemodem wedged in between (probably even worse).
Tobias
