Hello, I’m having problems with my rbs when more than one user connects to Wireguard at the same time, even though they have different connections, and when I disconnect the rb it doesn’t “detect” that I was disconnected, so I need to disconnect via the interface and connect my client again.
In another words (now it is my turn not to be sarcastic), your description is so vague that the only feedback you can get is consolation - yes, you are not alone, other people also have various sorts of issues with Wireguard, some of then even looking similar to your ones from the outside.
If you need a real advice and ultimately some solution, you have to provide much more information. Also, Wireguard does work in general, but like anything else, it has its limitations, so understanding what can and cannot be done is a key to finding a solution.
A good starting point is posting an export of your actual configuration for an audit - obfuscate any serial numbers and MAC addresses, public/global IP/IPv6 addresses, private or pre-shared keys, and user names used to log in to external services, but otherwise post the configuration unchanged. Issues typically hide in the parts of the configuration you do not expect to be related. Once we conclude that the configuration is OK, we can start debugging the individual issues.
