Hi there,
I want to try to set up a test environment for hAP ax3 as DHCPv6 Server. The topology of this environment is: hAP ax3 (LAN-Bridge)-(WAN)-DUT-(LAN)-PC. Now, regarding the setting of teaching resources on the Internet, currently the IPv6 Address can only be obtained by the DUT's WAN port, and the DUT's LAN cannot obtain it, and even the PC cannot obtain it. Attached below are my configuration files and RouterOS version, I hope it can be of help.
[admin@MikroTik] > /ipv6 address print
Flags: D - DYNAMIC; G - GLOBAL, L - LINK-LOCAL
Columns: ADDRESS, FROM-POOL, INTERFACE, ADVERTISE
ADDRESS FROM-POOL INTERFACE ADVERTISE
0 DL fe80::d601:c3ff:fe57:155/64 bridge-DHCP-v4-v6 no
1 DL fe80::d601:c3ff:fe57:156/64 PPPoE-Bridge no
;;; Create by Kuma
2 G fd00:2::1/64 ipv6-pool bridge-DHCP-v4-v6 yes
[admin@MikroTik] > /ipv6 route print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT
Columns: DST-ADDRESS, GATEWAY, DISTANCE
DST-ADDRESS GATEWAY DISTANCE
DAc fd00:2::/64 bridge-DHCP-v4-v6 0
DAc fe80::%bridge-DHCP-v4-v6/64 bridge-DHCP-v4-v6 0
DAc fe80::%PPPoE-Bridge/64 PPPoE-Bridge 0
[admin@MikroTik] > /ipv6 dhcp-server print
Columns: NAME, INTERFACE, ADDRESS-POOL, PREFERENCE, LEASE-TIME
NAME INTERFACE ADDRESS-POOL PREFERENCE LEASE-TIME
;;; Create by kuma
0 ipv6-dhcp-server bridge-DHCP-v4-v6 static-only 255 1d
[admin@MikroTik] > /ipv6 pool print
Columns: NAME, PREFIX, PREFIX-LENGTH
NAME PREFIX PREFIX-LENGTH
0 ipv6-pool fd00:2::/64 64
[admin@MikroTik] > /ipv6 dhcp-server lease print
bad command name lease (line 1 column 19)
[admin@MikroTik] > /ipv6 dhcp-client print
Columns: INTERFACE, STATUS, REQUEST
INTERFACE STATUS REQUEST
;;; Create by Kuma
0 bridge-DHCP-v4-v6 searching... prefix
[admin@MikroTik] > /ipv6 firewall filter print
Flags: X - disabled, I - invalid; D - dynamic
0 ;;; defconf: accept established,related,untracked
chain=input action=accept connection-state=established,related,untracked
1 ;;; defconf: drop invalid
chain=input action=drop connection-state=invalid
2 ;;; defconf: accept ICMPv6
chain=input action=accept protocol=icmpv6 log=no log-prefix=""
3 ;;; defconf: accept UDP traceroute
chain=input action=accept protocol=udp port=33434-33534
4 ;;; defconf: accept DHCPv6-Client prefix delegation.
chain=input action=accept protocol=udp src-address=fe80::/10 dst-port=546
5 ;;; defconf: accept IKE
chain=input action=accept protocol=udp dst-port=500,4500
6 ;;; defconf: accept ipsec AH
chain=input action=accept protocol=ipsec-ah
7 ;;; defconf: accept ipsec ESP
chain=input action=accept protocol=ipsec-esp
8 ;;; defconf: accept all that matches ipsec policy
chain=input action=accept ipsec-policy=in,ipsec
9 ;;; defconf: drop everything else not coming from LAN
chain=input action=drop in-interface-list=!LAN
10 ;;; defconf: accept established,related,untracked
chain=forward action=accept connection-state=established,related,untracked
11 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid
12 ;;; defconf: drop packets with bad src ipv6
chain=forward action=drop src-address-list=bad_ipv6
13 ;;; defconf: drop packets with bad dst ipv6
chain=forward action=drop dst-address-list=bad_ipv6
14 ;;; defconf: rfc4890 drop hop-limit=1
chain=forward action=drop protocol=icmpv6 hop-limit=equal:1
15 ;;; defconf: accept ICMPv6
chain=forward action=accept protocol=icmpv6
16 ;;; defconf: accept HIP
chain=forward action=accept protocol=139
17 ;;; defconf: accept IKE
chain=forward action=accept protocol=udp dst-port=500,4500
18 ;;; defconf: accept ipsec AH
chain=forward action=accept protocol=ipsec-ah
19 ;;; defconf: accept ipsec ESP
chain=forward action=accept protocol=ipsec-esp
20 ;;; defconf: accept all that matches ipsec policy
chain=forward action=accept ipsec-policy=in,ipsec
21 ;;; defconf: drop everything else not coming from LAN
chain=forward action=drop in-interface-list=!LAN
22 chain=input action=accept protocol=udp port=546 log=no log-prefix=""
23 chain=input action=accept protocol=icmpv6 log=no log-prefix=""
[admin@MikroTik] > dhcp-server config print
bad command name dhcp-server (line 1 column 1)
[admin@MikroTik] >
