Generating a .pcap from Mikrotik - ERROR
Hello, I´m using a RB 1100 AH X2, I´m trying to generate a .pcap from the RB using these commands:
/tool sniffer set file-name=example
/tool sniffer set memory-limit=10000 file-limit=100000
/tool sniffer start
/tool sniffer packet print
/tool sniffer stop
The problem is that when I open with wireshark the file generated the mac address are all 00:00:00:00:00:00. The RB is being used as a switch, I have a bridge between the interfaces.
Is there a way I can see the MAC address?
Thanks in advance
do you have ports switched and master-port added to bridge?
