Generating Report ROS v7 does not tally with the accounting
I’m a WISP, after upgrading to v7 the usermanager if fine and working well but I find very difficult to account the voucher sold within a period of time, unlinke in v6 when I can use the start column to sort and find vouchers activated within certain period.
I normally generate the vouchers in bulk, to be activated on first auth, so I want my reporting to show all vouchers that are activated within a month.
I used the script below, it only generate old from old user session and does not capture vouchers activated that same day, despite vouchers been sold and activated each day I tried the report generated remains the same.
:log info "Starting User Manager Report Generation..."
:delay 5
/user-manager/generate-report report-template=report_default.html columns=username,session-start,uptime,session-end,download,upload,terminate-cause,user-ip,acct-session-id
:log info "User Manager Report Generation Completed..."
I’ll be more than happy if someone can help out with a solution
Please someone should help me tag the mikrotik masters and professionals to advice on this, thank you.
