My inquire is about comunication through serial port on RB500.
Is there any way to read and write over RS232 port on RB? I have seen SIGWATCH but it doesn´t give me a complete solution. It only watches an electrical signal on serial port.
I would like to read data from that port, thus, perform some script with it.
Or may be write to some microprocessed application outside the RB.
Is it possible? how can I do it?
My purpose is to make a monitor/execution application (energy, alarm, reset powersupplay, etc.)
Thank you a lot. I will appreciate any help from you.
Ivan Perino
Argentina
MUM is near!
Hi, I apologize but I’m a beginner and I am a lot confused:
I would like to use a RB112 (1 COM) with a GPRS modem through serial port: if I’m not wrong I should command it through System → Serial-terminal serial0 but I receive the message “port is already in use”.
Whet’s wrong?
