I am creating a setup script for my favourite router RB5009UG+S+IN!
I’m wanting to create a basic setup script which can create a simple, secure network on a BT (in the UK) internet connection. The PPPoE details are generic and always work here so that makes my life easy! I like WAN on port 8 and LAN on ports 1-7 so quickset doesn’t work for me as I can only choose ports ether1 or sfp1.
I’d like some critique on my script, am I missing anything obvious or do you think I should add anything?
# SETUP LAN
/interface bridge add name=bridge1
/interface bridge port add interface=ether1 bridge=bridge1
/interface bridge port add interface=ether2 bridge=bridge1
/interface bridge port add interface=ether3 bridge=bridge1
/interface bridge port add interface=ether4 bridge=bridge1
/interface bridge port add interface=ether5 bridge=bridge1
/interface bridge port add interface=ether6 bridge=bridge1
/interface bridge port add interface=ether7 bridge=bridge1
/ip address add address=192.168.88.1/24 interface=bridge1
/ip dhcp-server/ setup
# SETUP WAN
/interface pppoe-out1
add disabled=no interface=ether8 user=bthomehub@btbroadband.com password=password \
add-default-route=yes use-peer-dns=yes
/interface list add name=LAN
/interface list member add list=LAN interface=bridge1
/tool mac-server set allowed-interface-list=LAN
/tool mac-server mac-winbox set allowed-interface-list=LAN
/ip neighbor discovery-settings set discover-interface-list=LAN
/user set 0 address=192.168.88.0/24
/ip service disable telnet,ftp,www,api
/ip service set winbox address=192.168.88.0/24
/tool bandwidth-server set enabled=no
/ip firewall nat add chain=srcnat out-interface=pppoe-out1 action=masquerade
# INPUT CHAIN - Handles traffic destined for the router itself
add chain=input action=accept connection-state=established,related,untracked comment="Accept established, related, untracked connections"
add chain=input action=accept protocol=icmp comment="Accept ICMP"
add chain=input action=drop connection-state=invalid comment="Drop invalid connections"
add chain=input action=drop in-interface=ether8 comment="Drop all other traffic on WAN interface"
# FORWARD CHAIN - Handles traffic passing through the router
add chain=forward action=fasttrack-connection connection-state=established,related comment="Fasttrack for established, related connections"
add chain=forward action=accept connection-state=established,related comment="Accept established, related connections"
add chain=forward action=drop connection-state=invalid comment="Drop invalid connections"
add chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether8 comment="Drop traffic from WAN to LAN not NATed"
# OUTPUT CHAIN - Handles traffic originating from the router itself (usually less restrictive)
add chain=output action=accept connection-state=established,related comment="Accept established, related connections"
add chain=output action=drop connection-state=invalid comment="Drop invalid connections"
# Logging - For troubleshooting and monitoring
add chain=input action=log log-prefix="INPUT DROP: " comment="Log dropped INPUT traffic"
add chain=forward action=log log-prefix="FORWARD DROP: " comment="Log dropped FORWARD traffic"
Thank you very much for the info @jaclaz. I’ll look into those points. I ran some testing on my script and have a new version, also linked to GitHub for version control. I plan on adding some more comments and information to make it compatible with 5 port devices such as my hex s etc. https://github.com/litecactus/mikrotik/tree/main
# Set timezone
/system clock set time-zone-name=Europe/London
# Set NTP server
/system ntp client set enabled=yes servers=0.uk.pool.ntp.org
# Create and configure bridge
# DHCP and DNS Setup
/ip pool add name=dhcp_pool ranges=192.168.88.10-192.168.88.254
/ip dhcp-server network add address=192.168.88.0/24 gateway=192.168.88.1 dns-server=1.1.1.2,9.9.9.9
/ip dns set servers=1.1.1.2,9.9.9.9 allow-remote-requests=yes
/ip dhcp-server add name=dhcp1 interface=bridge1 address-pool=dhcp_pool lease-time=1d
/ip dhcp-server enable dhcp1
# WAN PPPoE Client
/interface pppoe-client add name=pppoe-out1 disabled=no interface=ether8 user=bthomehub@btbroadband.com password=password add-default-route=yes use-peer-dns=yes
# FIREWALL INPUT CHAIN - Handles traffic destined for the router itself
# FIREWALL FORWARD CHAIN - Handles traffic passing through the router
# FIREWALL OUTPUT CHAIN - Handles traffic originating from the router itself (usually less restrictive)
# FIREWALL Logging - For troubleshooting and monitoring
# Configure Interface List and MAC Server
# Configure User and Services
No I guess not, I tend to have this enabled (even though port 53 is off) to ensure DNS replies internally as I see it as harmless in that sense? Too much?
I’ve added a Guest and DMZ VLAN now as well as a simple capsman config. I think this covers all the basics I need and anything further I’ll add as I go. https://github.com/litecactus/mikrotik/tree/main
