I’m currently using MeshAP and am having some issues with suppport and getting it to work with Aradial Radius. While i’m waiting for support I thought I’d see if …
Does Mikrotik RouterOS work on the Geode SC1100?
Does mikrotik work with Aradial Radius ?
Looking forward to some answers and suggestions. I may switch to RouterBoard but this all depends on replys and testing with MeshAP.
Anyone had experience with both MeshAP and Mikrotik? Preferences? I run 20 Meshing hotspots at the moment but am not too far down the track I think to switch technology.
If you’re going to switch to ROS you might as well switch to Routerboard over a Geode SBC while you’re at it as you will save $$$ and have comparable or better performance.
We also tried 16 MeshAP units in 2004.
Had to take all of it down. Major network dissruption.
MeshAP cannot compare to what you can do with Mikrotik.
I have to admit I do not know how MeshAP is now.
The kind of network we now have, were not going back.
