Is it possible to get 2 WANs static IP (from provider) on one interface ?
Or I have to use additional switch ?
router - CCR1036
Any help would be much appreciated!
Thank you !
router - CCR1036
Thank you !
Yes you can have multiple ip’s on any interface. You may need to do some routing things to return traffic over spicific ip’s though the return ip will be chosen based upon the route table.
