How get comment (from /ip route, /ip firewall filter, …) over API???
Thanks ![]()
Thanks ![]()
print and getall shows comments
/ip/firewall/filter/print
!re
=.id=*B
=chain=unused-hs-chain
=action=passthrough
=bytes=0
=packets=0
=invalid=false
=dynamic=false
=disabled=true
=comment=place hotspot rules here
If you want only comments, then
=.proplist=.id,comment
!re
=.id=*B
Thank You,
I had any script, but then did not work ![]()
Later, I found this information:
*What’s new in 3.28:
) api - value of ‘comment’ property was only returned from ‘system’ package programs;
I had 3.26 version… ![]()
