Hi guys, I need some help.
I have hAP ac^2 running on 7.4
I have several l2tp clients on my router, 2 wan, and a telegram bot. I succeed in making the telegram bot to send messages to my group. Now I want the followings:
I want the bot to send the list of uplink VPNs, something like:
Router ID: xxx <— no problem
mmm/dd/yyyy hh:mm:ss <— no problem
Connecting link: l2tp - xxx - Singapore <— run but only for 1 VPN, if there is more than 1 VPN connection, it shows nothing.
:local VPNNames [:put [/interface get [find where running type=l2tp-out] value-name=name]]
I understand that “find” returns the ID of the interface and “get” will get the interface name. but since there is more than 1 id, “get” gets the error. But I don’t know how to make it into a list and telegram can get that content to send message.
I have 2 wan, 1 from an LTE router and 1 from a PPPoE router. the VPNs connect through the LTE router just fine with no problem but cannot connect through the PPPoE router (it uses TR-069). Even when I disable the LTE router, no VPN can establish the link through the PPPoE router. Any suggestion?
a local variable only exists within the block where it was declared. So to let its contents survive the end of a run of the foreach body, you have to replace :foreach vpnID in=$vpnID do={:local vpnNames [/interface get $vpnID value-name=name]}
by :local vpnNames
:foreach vpnID in=$vpnID do={:set vpnNames [/interface get $vpnID value-name=name]}
it seems you want to send the whole list of interfaces in a single message; if so, you have to update it rather than rewrite it each time: :local vpnNames [:toarray “”]
:foreach vpnID in=$vpnID do={:set vpnNames ($vpnNames,[/interface get $vpnID value-name=name])}
:local MessageText ("Router ID: $deviceName%0A$deviceDate $deviceTime%0AConnecting link: " . [:tostr $vpnNames])
(or use a flat string instead of an array: :set vpnNames ($vpnNames . " " . [/interface get $vpnID value-name=name]) and no need for the :tostr, you’ll just have the separator before the last interface name unless you strip it using :pick, or unless you use an additional condition to only add it if the $vpnNames is not empty)
you can also send a message each time the state of the L2TP interface changes if you configure the on-up and on-down scripts on the /ppp profile row used by the /ppp secret rows at the server side. The on-down script is pre-cached during the on-up operation, so a change in the on-down script only actually becomes noticeable at the second down after the change. The pleasant side (and most likely the purpose) of this is that the values of the variables are pre-cached too, so even when the interface is dynamic and therefore doesn’t exist any more when the on-down script is executed, its name is still available for logging or sending.
About VPNCount, better use a global variable than a file.
If the file not exist, the script do not create one.
At least add a check if the file exist go, else create first one file, then put 0 inside, then continue the execution of the script.
If you create a file outside /flash on device that have flash, on reboot the file is lost, also like with global variable.
:put prints the on the script console, it does not provide the as an output value to the calling function.
Second, if you want to use another separator than ‘;’ (which is inserted by :tostr), you cannot add the VPN names into an array - instead, you have to follow my previous advice to start with an empty string, and add each new VPN interface name followed by the ‘%0a’ separator to the end of this string in the :foreach cycle. Then, you just copy the resulting string into the final message, without the :tostr.
Thank you so much for the correction. So the point here is "$VPNNames%0A$[". So "%0A" is for a new line and "$[" is for each string in that array, am I right?
furthermore, there is a space between connection and output. Can I make it disappear?
