Hi all,
First post! So happy to be here.
I wanted to check cpu usage in an LtAP mini LTE device (RB912R-2nD-LTm&R11e-LTE-US). Works fine with the print command, but not with get (I need “get” to be able to use it in a script later).
Below you can see “print” works fine, “get” returns nothing, but it actually works as if I type wrong value name, it does throw an error:
[admin@Mikrotik] > /system resource print
uptime: 2d4h34m57s
version: 6.48.5 (long-term)
build-time: Sep/21/2021 13:50:51
factory-software: 6.44.6
free-memory: 40.0MiB
total-memory: 64.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 650MHz
cpu-load: 10%
free-hdd-space: 3248.0KiB
total-hdd-space: 16.0MiB
write-sect-since-reboot: 1253
write-sect-total: 17759
bad-blocks: 0%
architecture-name: mipsbe
board-name: LtAP mini LTE kit
platform: MikroTik
[admin@Mikrotik] > /system resource get cpu-load
[admin@Mikrotik] > /system resource get cpu-loaddd
input does not match any value of value-name
[admin@Mikrotik] >
Am I doing something wrong? Possible bug in 6.48.5? (It’s almost-latest long-term release, I did not find anything related in release notes for a newer version).
Thanks in advance to all the community!
