Get Flags
Is there a way to use the get command for flags?
I want to create a script based on whether a usb port is flagged inactive.
I can get the status of every other parameter, ie:
:put [/port get [/port find name=“usb2”] used-by]
Is there a parameter for status? Or another way to do this?
Thanks,
Mike
