Get GPS values
After v6.39 i noticed a GPS tab with latitude,longitute,speed etc, but i cannot get any value from command line or script (ex. /system gps get latitude).
I used to get those values by exporting them to a file ( /system gps monitor file=gps.txt ) and searching for each value separately.
Is there any other way i can get those values?
Thanks in advance.
Mikrotiks sport a gps device?
You can use the “do” argument, e.g.
/system gps monitor once do={
:put $longitude;
:put $latitude;
:put $speed;
To find out all available variables inside the “do”, write “$” and press the Tab key while inside the “do” block.
Yes and no. RouterOS supports certain GPS devices via USB or serial ports, but AFAIK, no MikroTik router sports a built in one. See this section in the manual.
