It’s an associative array access operator.
Arrays can have not just indexes, but “keys” also. f.e.
{a=1;b=2;3;4}
is an array where the first member has the key “a” and the value “1”, a second member with key “b” and value “2”, a third member with no key and a value of “3”, and a forth member with no key and a value of “4”.
When you use :pick, you get the value of an item at a particular index (regardless of its key), with 0 being the first member, 1 being the second and so on, so
:put [:pick ({a=1;b=2;3;4}) 1]
outputs “2”.
With the “->” operator, you can instead target an item by its key, so
:put (({a=1;b=2;3;4})->"b")
outputs “2”, and it will still output “2”, regardless of where “b” is in the array, e.g.
:put (({a=1;3;4;b=2})->"b")
:put (({b=2;a=1;3;4})->"b")
all return “2”, while
:put [:pick ({a=1;3;4;b=2}) 1]
would output “3”, and
:put [:pick ({b=2;a=1;3;4}) 1]
would output “1”.
When you use “info as-value”, an associative array is returned, where the property name is the key, and the property’s value is the array value. You could use :pick to get a particular item, but as RouterOS versions change, the property may be moved around. Using “->” allows you to keep referring to the same item, as long as the property name stays the same.
If you’re asking about its syntax and why it’s the way it is… Long story short, bad language design on top of bad language design. All the brackets are used to make it clear to the parser which is which and which is where in the order of things, because the parser is not smart enough to figure it out otherwise. The quotes on the right side of “->” are supposed to be optional when there’s no space or dash in the property name, but certainly in older versions (I’m not sure about newer ones), there were bugs when you omit them.
