Get infrmation from Sierra Wireless MC8790
Hi All,
i configured teh routerboard RB411U with a sierra Wireless MC8790, all work but i can not get a information about the 3G module:
PPP CONFIGURATION :
[admin@TEST_PT] /interface ppp-client> print
 0  R name="ppp-3G" max-mtu=1500 max-mru=1500 mrru=disabled port=usb2 data-channel=3 info-channel=3
      apn="internet.wind.biz" pin="" user="" password="" profile=default phone="*99***1#" dial-command="ATDT"
      modem-init="" null-modem=no dial-on-demand=yes add-default-route=yes use-peer-dns=yes
      keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
I can get info from module if the ppp-client is disble, but if the ppp-client is connect i can not get information about the module.
Can i get information during the connection ?
Regards
Cris
Cris, different info-channel should report you necessary information.
hi Sergejs, i tried differnt solution, but seems that this is only working solution.
      data-channel=4 info-channel=3 apn="internet.wind.biz" pin="" user=""
      modem-init="" null-modem=no dial-on-demand=no add-default-route=yes
      use-peer-dns=yes keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
and this is the info during the connection :
  status: call in progress
         pin-status: no password required
      functionality: full
         gprs-class: A - GPRS & GSM simultaneous
       manufacturer: Sierra Wireless, Incorporated
              model: MC8790
           revision: K2_0_7_35AP C:/WS/FW/K2_0_7_35AP/MSM6290/SRC 2010/03/04
                     17:37:08
      serial-number: xxxxxxxxxxxxxxx
   current-operator: I WIND
  access-technology: GSM compact
     signal-strengh: -65
   frame-error-rate: unknown
-- [Q quit|D dump|C-z pause]
if i try to switch the channell " data-channel=3, info-channel=4 " the router is still connected but i can not get info .
It is the correct configuration with " data-channel=4 and info-channel=3 " ?
Thank for yout tips .
Cris
P.S. Sorry for my english but i still learn :smiley:
Hi all,
during the test i saw that the last configuration don’t work correctly, the modem 3G disconnects every 1 minute.
Same logs :
09:13:46 async,ppp,info ppp-3G: disconnected
09:13:47 async,ppp,info ppp-3G: initializing...
09:13:47 async,ppp,info ppp-3G: reseting link...
09:13:48 async,ppp,info ppp-3G: initializing modem...
09:13:48 async,ppp,info ppp-3G: dialing out...
09:13:48 async,ppp,debug ppp-3G: LCP lowerup
09:13:48 async,ppp,debug ppp-3G: LCP open
09:13:48 async,ppp,debug,packet  ppp-3G: sent LCP ConfReq id=0x3d
09:13:48 async,ppp,debug,packet    <magic 0x19b31cdc>
09:13:48 async,ppp,debug,packet    <pcomp>
09:13:48 async,ppp,debug,packet    <accomp>
09:13:48 async,ppp,debug,packet  ppp-3G: rcvd LCP ConfReq id=0x45
09:13:48 async,ppp,debug,packet    <asyncmap 0x0>
09:13:48 async,ppp,debug,packet    <magic 0x1dd20444>
09:13:48 async,ppp,debug,packet    <auth  chap>
09:13:48 async,ppp,debug,packet  ppp-3G: sent LCP ConfAck id=0x45
09:13:48 async,ppp,debug,packet  ppp-3G: rcvd LCP ConfAck id=0x3d
09:13:48 async,ppp,debug ppp-3G: LCP opened
09:13:48 async,ppp,debug,packet  ppp-3G: rcvd LCP DiscReq id=0x46
09:13:48 async,ppp,debug,packet  ppp-3G: rcvd CHAP Challenge id=0x1
09:13:48 async,ppp,debug,packet     <challenge len=10>
09:13:48 async,ppp,debug,packet     <name UMTS_CHAP_SRVR>
09:13:48 async,ppp,debug,packet  ppp-3G: sent CHAP Response id=0x1
09:13:48 async,ppp,debug,packet     <response len=10>
09:13:48 async,ppp,debug,packet  ppp-3G: rcvd CHAP Success id=0x1
09:13:48 async,ppp,info ppp-3G: authenticated
09:13:48 async,ppp,debug ppp-3G: IPCP lowerup
09:13:48 async,ppp,debug,packet  ppp-3G: sent IPCP ConfReq id=0x8e
09:13:48 async,ppp,debug,packet     <addr 0.0.0.0>
09:13:48 async,ppp,debug,packet     <ms-dns 0.0.0.0>
09:13:48 async,ppp,debug ppp-3G: IPCP open
09:13:48 async,ppp,debug ppp-3G: IPV6CP lowerup
09:13:48 async,ppp,debug,packet  ppp-3G: sent IPV6CP ConfReq id=0x2b
09:13:48 async,ppp,debug,packet     <interface-identifier 0:0:0:3>
09:13:48 async,ppp,debug ppp-3G: IPV6CP open
09:13:48 async,ppp,debug ppp-3G: MPLSCP lowerup
09:13:48 async,ppp,debug,packet  ppp-3G: sent MPLSCP ConfReq id=0x1d
09:13:48 async,ppp,debug ppp-3G: MPLSCP open
09:13:48 async,ppp,debug ppp-3G: BCP open
09:13:48 async,ppp,debug ppp-3G: CCP lowerup
09:13:48 async,ppp,debug ppp-3G: CCP open
09:13:48 async,ppp,debug,packet  ppp-3G: rcvd LCP ProtRej id=0x47
09:13:48 async,ppp,debug,packet      82 81 01 1d 00 04
09:13:49 async,ppp,debug ppp-3G: IPCP timer
09:13:49 async,ppp,debug,packet  ppp-3G: sent IPCP ConfReq id=0x8f
09:13:49 async,ppp,debug,packet     <addr 0.0.0.0>
09:13:49 async,ppp,debug,packet     <ms-dns 0.0.0.0>
09:13:50 async,ppp,debug,packet  ppp-3G: rcvd IPCP ConfNak id=0x8f
09:13:50 async,ppp,debug,packet     <ms-dns 10.11.12.13>
09:13:50 async,ppp,debug,packet     <ms-dns 10.11.12.14>
09:13:50 async,ppp,debug,packet  ppp-3G: sent IPCP ConfReq id=0x90
09:13:50 async,ppp,debug,packet     <addr 0.0.0.0>
09:13:51 async,ppp,debug,packet  ppp-3G: rcvd IPCP ConfNak id=0x90
09:13:51 async,ppp,debug,packet     <ms-dns 10.11.12.13>
09:13:51 async,ppp,debug,packet     <ms-dns 10.11.12.14>
09:13:51 async,ppp,debug,packet  ppp-3G: sent IPCP ConfReq id=0x91
09:13:51 async,ppp,debug,packet     <addr 0.0.0.0>
09:13:52 async,ppp,debug,packet  ppp-3G: rcvd IPCP ConfReq id=0x2e
09:13:52 async,ppp,debug,packet  ppp-3G: sent IPCP ConfNak id=0x2e
09:13:52 async,ppp,debug,packet     <addr 0.0.0.0>
09:13:52 async,ppp,debug,packet  ppp-3G: rcvd IPCP ConfNak id=0x91
09:13:52 async,ppp,debug,packet     <addr 151.31.240.110>
09:13:52 async,ppp,debug,packet     <ms-dns 193.70.152.25>
09:13:52 async,ppp,debug,packet     <ms-dns 193.70.192.25>
09:13:52 async,ppp,debug,packet  ppp-3G: sent IPCP ConfReq id=0x92
09:13:52 async,ppp,debug,packet  ppp-3G: rcvd IPCP ConfReq id=0x2f
09:13:52 async,ppp,debug,packet  ppp-3G: sent IPCP ConfAck id=0x2f
09:13:52 async,ppp,debug,packet  ppp-3G: rcvd IPCP ConfAck id=0x92
09:13:52 async,ppp,debug ppp-3G: IPCP opened
09:13:52 async,ppp,info ppp-3G: could not determine remote address, using 10.112.112.182
09:13:52 async,ppp,info ppp-3G: connected
If i change the port data-channel field with " 3 " the modem working correctly but i can not get info.
Some suggestion ?
Regards.
Cris
From Supported Hardware documentation,
Sierra Wireless MC8790 v3.18 Few models do not send echo for input commands, modem does not work properly.
It does not support proper info on other channels, you can upgrade modem firmware to the latest one or wait for the fixes in the upcoming firmware. MikroTik can do nothing in this situation.
