I want to use IP of interface in my script. I get IP address by command
:global addr [/ip address get [find interface="bridge1"] address]
If on the interface is just one IP, it works. But when on the interface are two or more IPs, it displays error message “invalid internal item number” . Any ideas?
Is there any option to filter it by their flags? For example, in IPv6, an interface has several addresses with different flags, and if I only need to get the global address, how can I do that?
diamuxin: Thanks for reply, but I was referring to getting an IP address in general, not just a public. Specifically, the cloud is good choice for somebody but I am not using.
trkk: This could be a solution for the original interviewer, but it won’t help me. I am looking for a way to filter and get IP addresses according to their flags. I asked my question in this thread because it applies to the same topic, but I am not the author of the original question.
By the way, the :put command should be inside of the for loop, right?
Sorry, I confused you and OP.
Unfortunately there is no flag that indicates the IPv4 address is global or not, so we have to do like this.
> :put [/ip/address/find where !(address in 192.168.0.0/16) and !(address in 172.16.0.0/12) and !(address in 10.0.0.0/8)]
You may know, we can see usable query parameters by
> /ip/address/find where <press F1 here>
And about
the answer is No.
That code stores addresses into an array then puts array’s data at outside of the loop. Maybe I had to write “addresses” rather than shorten “addrs” (= addr + ‘s’ of plural form, sorry .
Ah, I see. I read your qustion wrongly, like
“/ip/address doesn’t have parameters (flags) unlinke IPv6 (/ipv6/address), so I can’t pick up global IPv4 addresses.”
So, if you want to pick up global IPv6 addresses, simply do “/ipv6/address/find where global”.
:local addresses [:toarray ""]
/ipv6/address
:foreach id in=[find interface="bridge1" global] do={
# do something, like
:set addresses {$addresses , [get $id address]}
:put $addresses
OK, thanks for the kick. Now I found out that besides global, invalid and dynamic, link-local is also usable. Static can’t be used as the parameter, I don’t even know why. Are these existing and usable parameters listed somewhere in the Mikrotik documentation?
/ipv6 address print where interface=WAN and global
:local wanipv6global [/ipv6 address get [find where interface=WAN and global] address]
Obviously some problems can occour if the interface have more than one address…
Trying to not forget one, one IPv6 can have one or more flags: disabled
dynamic
global
invalid
link-local
on v7: preferred
valid
some not exist but are easy doable:
enabled is: !disabled
static is: !dynamic
on v6: valid is: !invalid
and on v7 “not preferred” is: !preferred
Obviously some are esclusive, for example global can’t be link-local, etc.
