Get IPv6 via VPN/tunel from another MK
Hello, i have an IPv6 sixxs tunnel at work (rb493) with a /64 on it, and i want to enable IPv6 at my home network (rb433) over VPN or something to work, isolated from its IPv4 LAN
I tried PPTP but was not able to get an IP, anyone has an idea or article for me to learn?
if you have 2 independent (ipv4 only) lines to internet, and in work have sixxs tunnel to do IPv6…
the most logically is make a other tunnel IPv6 in home to do a IPv6 tunnel with the ip of work.
the schema is:
work->mytunel->work_router->tunnel->tunnelbroker->internet<-tunnelbroker<-tunnel<-home_router<-mytunnel<-home
i’m not sure what tunnels in router os works with ipv6, the eoipv6 native from mikrotik works well, makes a new interface and send all traffic for it, or do routes for your ip to prevent all internet traffic travel in the tunnel
thanks, maybe im missing something, but i think i have to do the tunnel over ipv4 because ipv6 (tunelbroker) is VERY slow at home, thats why my idea was to use the ipv6 tunnel from work
the problem is broke the tunnel in your home.
you can try to setup a EOIP tunnel in both mikrotiks in ipv4 and redirect in home the ipv6 traffic to eoip interface
or change tunnelbroker in home, i use tunnelbroker and select the node nearest to you home
thanks dcarrera, i’ll try that!
