Hi!
Our internet connection here comes in via some CPE box, which when google the model number, basically is a managed switch. To this box I have my MikroTik router connected to one port and the TV box to another port. The MT gets a public IP from our ISP.
Now, since a MT router can do pretty much anything, I was thinking it would be nice to be able to get rid of the CPE box and just use my router. That is, connecting the cable that now connects to the WAN port on the CPE box, to the WAN port of the router and connect the TV box to one of the unused port on the router and by the magic of RouterOS, “simulate” the CPE box. I want this for two reasons; one, because it would make the setup much cleaner and get rid of a rather bulky box and two, save a few watts of electricity. This is what I’ve tested and figured out so far:
Router and TV box can be connected to any ports on the CPE box.
If I disconnect the incoming cable from the box and connect it directly to the WAN port of my router, internet works as just as it does with the CPE box, but I can obviously no longer watch TV.
If I test the CPE box internally in my own network as a regular switch, traffic flows to and from the WAN port and any of the LAN ports, but not between the LAN ports.
Now, VLAN’s is one of those things I never learned and got a grip on, but given my findings above, I assume that the CPE box doesn’t use any VLAN magic, but is basically just a regular switch, but with port isolation. I found a MikroTik article how to set up a bridge with port isolation, so I assume a “dirty” way of doing this would be to use three ports on the router, set up a bridge with port isolation on those ports and connect the incoming cable (the one normally connected to the WAN port of the CPE box) to one port, connect the TV box to another and just loop a short cable from the then “internet” port to the WAN port on the router. This wouldn’t be very neat and I’m also one port short, since I’m already using three ports on the router, which is a 5 port hEX.
Could what I want to do be achieved?
All the best!
