In 7.15+, you should be able to use the new [:deserialize from=dsv]. So for quick example...
:local kvtxt "SCRIPT_VERSION=1.2.1\r\nREQ_ID=01J8C5ZV2AY6V6HWEB6F4HQJW5\r\nREQ_IP=172.21.104.34\r\nREQ_FAMILY=1\r\nREQ_CREATED=2024-09-22 06:16:32"
# now use :deserialize to get an RouterOS array from file txt
:local kvarray [:deserialize delimiter=("=") from=dsv options=dsv.plain [:tocrlf $kvtxt]]
# yes, it's an array
:put [:typeof $kvarray]
:put $kvarray
# to better see what got parsed, :serialize's "pretty json" provides a nice output of the array:
:put [:serialize to=json options=json.pretty $kvarray]
# and can use scripting to find the values using ->0 for the key, and ->1 to get to useful form:
:local myconfig [:toarray ""]
:foreach v in=$kvarray do={ :set ($myconfig->($v->0)) ($v->1) }
:put $myconfig
:put ($myconfig->"SCRIPT_VERSION")
array
SCRIPT_VERSION;1.2.1;REQ_ID;01J8C5ZV2AY6V6HWEB6F4HQJW5;REQ_IP;172.21.104.34;REQ_FAMILY;1;REQ_CREATED;2024-09-22 06:16:32
"SCRIPT_VERSION",
"1.2.1"
"REQ_ID",
"01J8C5ZV2AY6V6HWEB6F4HQJW5"
"REQ_IP",
"172.21.104.34"
"REQ_FAMILY",
1
"REQ_CREATED",
"2024-09-22 06:16:32"
REQ_CREATED=2024-09-22 06:16:32;REQ_FAMILY=1;REQ_ID=01J8C5ZV2AY6V6HWEB6F4HQJW5;REQ_IP=172.21.104.34;SCRIPT_VERSION=1.2.1
1.2.1
Without showing what happening, the above could be simplified change the "kvfilename" as needed:
change file name with above format
:local kvfilename "kvfile"
process the file into an array using :deserialize
:local kvtxt [/file get $kvfilename contents]
this "pivots" the array-of-tuples returned from deserialize...into a normal key-value array
to use then it's just
:put ($myconfig->"REQ_ID")
:put ($myconfig->"REQ_IP")
:put ($myconfig->"REQ_FAMILY")
:put ($myconfig->"REQ_CREATED")
1.2.1
172.21.104.34
1
2024-09-22 06:16:32
The array stuff is confusing at first but :deserialize does "half of the parsing", the array are easier "flip" than parsing using :pick and :find. Now tt be better if ' from=dsv options=...' had option to deal with tuples like your key=value\n... case - to avoid the :foreach above.
Scripting - RouterOS - MikroTik Documentation has the docs on :serialize and :deserialize stuff.
There is a video from Mikrotik on working with arrays:
https://www.youtube.com/watch?v=eWCJw0uZ-lE
