Get version number in variable
Currently we can do the following in our script to create variable which holds the serial of the device:
:global serial [/system routerboard get serial-number]
However, we would like to set a variable which holds the version of the device for example:
:global serial [/system routerboard get version]
The above does not work…
I have tried doing the following:
:global version [/system resource print]
However, not only does it contain more information than what we need, when I print out the variable with
:put $version
it comes up with
input does not match any value of value-name
Any help would be much appreciated…
Maybe this will help !
:global version ([/system resource print as-value] -> "version")
Do not use print on scripts, until command already exist for do the same on simpler way.
What exactly you want?
RouterOS version
:global rosver [/system resource get version]
or RouterBOOT version?
:global rbootver [/system routerboard get current-firmware]
Thanks very much, both work well!
