Getting a lot of probabily loop between two equipment
I have the follow configuration
1 RB2011 with eth9 with TWO VLANS 100 and 300
1 RB433 with eth1 linked to the RB2011-eth9 and the same two VLANS 100 and 300.
but I am getting hundreds of this:
12:49:09 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:49:51 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:50:39 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:51:11 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:51:46 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:52:41 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:53:13 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:54:10 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:55:12 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:56:06 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:56:41 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:56:59 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:57:41 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:57:57 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:58:26 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:58:52 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:59:41 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0c:42:bc:80:32), probably loop
12:59:55 interface,warning vlan-100-eth9: bridge port received packet with own address as source address (00:0
Here some interesting configuration form the RB2011
[admin@Sprinfield Mikrotik] /interface vlan> export
jun/24/2018 13:01:28 by RouterOS 6.42.3
software id = 4TII-J7X2
model = 2011UiAS-2HnD
serial number = 46730161D89E
/interface vlan
add interface=ether9-slave-local name=vlan-100-eth9 use-service-tag=yes vlan-id=100
add interface=ether9-slave-local name=vlan-300-eth9 use-service-tag=yes vlan-id=300
add fast-forward=no name=bridge-airbnb
add fast-forward=no name=bridge-clientes
add admin-mac=00:0C:42:BC:80:2B auto-mac=no fast-forward=no name=bridge-local
add bridge=bridge-local interface=ether6-master-local pvid=100
add bridge=bridge-local hw=no interface=sfp1 pvid=100
add bridge=bridge-airbnb interface=airbnb
add bridge=bridge-local interface=wlan1 pvid=100
add bridge=bridge-local interface=amer-sup
add bridge=bridge-local interface=ether2-master-local pvid=100
add bridge=bridge-local interface=ether3-slave-local pvid=100
add bridge=bridge-local interface=ether4-slave-local pvid=100
add bridge=bridge-local interface=ether5-slave-local pvid=100
add bridge=bridge-local interface=ether7-slave-local pvid=100
add bridge=bridge-local interface=ether8-slave-local pvid=100
add bridge=bridge-local disabled=yes interface=ether9-slave-local pvid=100
add bridge=bridge-local interface=ether10-slave-local pvid=100
add bridge=bridge-clientes interface=vlan-300-eth9 pvid=300
add bridge=bridge-local interface=vlan-100-eth9 pvid=100
/interface bridge vlan
add bridge=bridge-local vlan-ids=100
add bridge=bridge-clientes vlan-ids=300
[admin@Sprinfield Mikrotik] /interface bridge vlan> export
jun/24/2018 13:03:04 by RouterOS 6.42.3
And now in the 433
[admin@Switch-customer+AP] /interface vlan> export
jun/24/2018 13:04:49 by RouterOS 6.42.2
software id = KWLQ-ZVNY
model = 493
serial number = 33BD027D1B43
/interface vlan
add interface=ether1 name=vlan-100-eth1 use-service-tag=yes vlan-id=100
add interface=ether3-slave name=vlan-100-eth3 use-service-tag=yes vlan-id=100
add interface=ether1 name=vlan-300-eth1 use-service-tag=yes vlan-id=300
add disabled=yes interface=ether5-slave name=vlan-300-eth5 use-service-tag=yes vlan-id=300
[admin@Switch-customer+AP] /interface bridge> export
jun/24/2018 13:05:24 by RouterOS 6.42.2
model = 493
add admin-mac=D4:CA:6D:40:1A:68 auto-mac=no fast-forward=no name=bridge-clientes
add fast-forward=no name=bridge-local
add bridge=bridge-local disabled=yes interface=ether1
add bridge=bridge-clientes interface=ether2-master pvid=300
add bridge=bridge-local interface=wireless-01-24 pvid=100
add bridge=bridge-clientes interface=ether3-slave pvid=100
add bridge=bridge-clientes interface=ether4-slave pvid=300
add bridge=bridge-clientes interface=ether5-slave pvid=300
add bridge=bridge-clientes interface=ether6-slave pvid=300
add bridge=bridge-clientes interface=ether7-slave pvid=300
add bridge=bridge-clientes interface=ether8-slave pvid=300
add bridge=bridge-clientes interface=ether9-slave pvid=300
add bridge=bridge-clientes interface=vlan-300-eth1
add bridge=bridge-local interface=vlan-100-eth3
add bridge=bridge-local interface=vlan-100-eth1
add bridge=bridge-local tagged=vlan-100-eth1 untagged=ether1 vlan-ids=100
[admin@Switch-customer+AP] /interface bridge vlan> export
jun/24/2018 13:06:13 by RouterOS 6.42.2
model = 493
I am getting the errors only in the RB2011.
Any body could help me? I am learning with VLANs and I am almost sure is a little mistake in my configuration
Thank you
