I am trying to replace a combined router and ADSL modem (Draytek Vigor 2600) with a seperate modem (D-Link DSL-300T) and Mikrotik. I’ve been trying for a few days now and I’m starting to get desperate!
I have tried to copy the configuration from the Draytek which looks like this:
Key: C - connected, S - static, R - RIP, * - default, ~ - private
0.0.0.0/ 0.0.0.0 via 62.3.83.3, IF3
C X.X.X.240/ 255.255.255.248 is directly connected, IF0
C~ 192.168.50.0/ 255.255.255.0 is directly connected, IF0
(IF0 = LAN port, IF3= WAN port)
Interface 0 Ethernet: Status: UP
IP Address: 192.168.50.1 Netmask: 0xFFFFFF00 (Private) (/24)
IP Address: X.X.X.246 Netmask: 0xFFFFFFF8 (/29)
MAC: 00-50-7F-22-D4-8D
Interface 3 PPPoE: Status: UP
IP Address: X.X.X.246 Netmask: 0xFFFFFFFF (/32)
MAC: 00-50-7F-22-D4-8E
My assigned public address range is X.X.X.240-247. My ISP tells me that 62.3.83.3 is their ADSL gateway. I have set up addresses on the mikrotik like this:
[admin@pad001X] ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.0.1/24 192.168.0.0 192.168.0.255 private
1 X.X.X.246/29 X.X.X.240 X.X.X.247 private
2 X.X.X.246/32 X.X.X.246 X.X.X.246 public
When I add a default route, MT assigns it to the private interface:
[admin@pad001X] ip route> print
Flags: X - disabled, I - invalid, D - dynamic, J - rejected,
C - connect, S - static, r - rip, o - ospf, b - bgp
DST-ADDRESS G GATEWAY DISTANCE INTERFACE
0 S 0.0.0.0/0 r X.X.X.246 1 private
1 DC 192.168.0.0/24 r 0.0.0.0 0 private
2 DC X.X.X.240/29 r 0.0.0.0 0 private
So, of course, no routing takes place. I also tried setting up a DHCP client on the public interface with “add default route” enabled, but MT shows the route as invalid. How can I get this setup to work?
Any advice appreciated.
Guy
