getting error when try do netinstall
I’m trying to reset the RB , and when I use the Netinstall I get this error message and can’t continue
Press any key within 2 seconds to enter setup..
kernel not found
trying bootp protocol… OK
Got IP address: 10.0.0.2
resolved mac address 18:03:73:A9:6C:5E
transfer started … transfer ok, time=7.20s
setting up elf image… OK
jumping to kernel code
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
anyone know what can I do?
What RouterBOARD do you try to Netinstall?
Make sure the latest Netinstall version is used (6.7 available for download from MikroTik.com).
have the latest version
and now this is what I get:
RouterBOOT booter 2.5
RouterBoard 133
CPU frequency: 175 MHz
Memory size: 32 MB
Boot configuration reset, applying defaults
writing settings to flash… OK
kernel not found
transfer started … transfer ok, time=7.21s
Oops[#1]:
Cpu 0
$ 0 : 00000000 00000001 00000000 00000001
$ 4 : 81d35000 00000004 803d0000 00010000
$ 8 : 73666873 81d3516c 00000000 81c0d4c0
$12 : 810425e0 810425e4 00000000 00000001
$16 : 81d35000 803e5330 8020f1b4 81c93aa0
$20 : 00000000 00008001 00000001 81c93a90
$24 : 00000000 00000000
$28 : 81c20000 81c21cf0 ffffffea 8020f0b8
Hi : 0000000b
Lo : 00000000
epc : 8020f0b0 squashfs_kill_sb+0x14/0x38
Not tainted
ra : 8020f0b8 squashfs_kill_sb+0x1c/0x38
Status: 10008c03 KERNEL EXL IE
Cause : 90800008
BadVA : 00000000
PrId : 0001800b (MIPS 4Kc)
Process swapper (pid: 1, threadinfo=81c20000, task=81c1c000, tls=00000000)
Stack : 00000000 81d0a005 81c0c7b8 00000000 81d35000 801b3bac 81d35000 00008001
8020f1b4 81c93aa0 00000000 81d35000 ffffffea 801b4320 81c93aa0 8042ab58
801b3494 80430000 81c0b6c0 81c0b6c0 803e5330 803e5330 81c93aa0 801b4fb8
81d0d000 00008001 ffffffea 803e5330 81c93a90 81c93aa0 81c0b6c0 803e5330
81c93a90 801cc0e4 01c0d8cc 801cb314 81d0d001 00000000 00008001 81c93aa0
Call Trace:
[<8020f0b0>] squashfs_kill_sb+0x14/0x38
[<801b3bac>] deactivate_locked_super+0xb4/0xfc
[<801b4320>] mount_nodev+0x6c/0xbc
[<801b4fb8>] mount_fs+0x20/0xe8
[<801cc0e4>] vfs_kern_mount+0x5c/0xd4
[<801cc3dc>] do_kern_mount+0x44/0xf8
[<801cdf2c>] do_mount+0x5c4/0x678
[<801ce084>] sys_mount+0x94/0xe4
[<803f4cbc>] mount_block_root+0x12c/0x2d0
[<803f509c>] prepare_namespace+0x1c8/0x20c
[<803f4a68>] kernel_init+0x114/0x11c
[<801077f0>] kernel_thread_helper+0x10/0x18
Code: afb00010 8c820194 00808021 <0c06cbe3> 8c440000 0c06cd88 02002021 8fbf0014 8e040194
—[ end trace b4beff68489a1bf9 ]—
Kernel panic - not syncing: Attempted to kill init!
