Sorry for the delay but I had to check some configuration options.
I was testing a couple of configuration scenarios in 3rd location, using HEX760 and Cap XL ac.
There should be 600/30 Mb/s of speed. When I’m using wired connection the speed is about 570-590 / 27-30.
After a lot of changes I finally get 400-420 / 25-30 by wireless connection.
Of course this is better than 50% I got before (280-300) but still it is not acceptable for me.
Especially, when I replaced Cap XL with Ubiquiti UAP AC LITE (the old version, not the new one) with almost default configuration I got 500-520.
After few fixes there was 550-570 and this is what I am expect from MT.
There are the best configs I am able to do:
- hex760iGS as an edge-router and capsman at the same time. there is default config with my changes:
/caps-man channel
add band=5ghz-onlyac control-channel-width=20mhz extension-channel=Ceee \
frequency=5180 name=ch-5
/caps-man datapath
add local-forwarding=yes name=datapath1
add name=bridge
/caps-man rates
add basic=12Mbps,24Mbps,36Mbps,48Mbps,54Mbps name=rate-5g supported=\
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm \
name=xl123
/caps-man configuration
add channel=ch-5 country=poland datapath=datapath1 distance=indoors \
hw-protection-mode=rts-cts hw-retries=5 installation=indoor mode=ap \
multicast-helper=full name=cfg-5 rates=rate-5g security=xl123 ssid=xl123
add comment=defconf name=WAN
add comment=defconf name=LAN
add include=WAN name=MGMT
/interface lte apn
add name=dhcp_pool0 ranges=172.31.4.2-172.31.4.254
add address-pool=dhcp_pool0 interface=bridge name=dhcp1
/port
set 0 name=serial0
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=\
cfg-5 name-format=identity name-prefix=5G
add bridge=bridge ingress-filtering=no interface=ether3
add bridge=bridge ingress-filtering=no interface=ether4
add bridge=bridge ingress-filtering=no interface=ether1
set discover-interface-list=MGMT
/ipv6 settings
add interface=ether2 list=WAN
add interface=bridge list=LAN
add interface=ether5 list=MGMT
/interface ovpn-server server
set auth=sha1,md5
add address=172.31.4.1/24 interface=bridge network=172.31.4.0
/ip dhcp-client
add address=172.31.4.0/24 gateway=172.31.4.1
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=test-main
/system routerboard settings
set silent-boot=yes
/tool romon
set enabled=yes
- Cap xl ac as the Cap itself
there is default caps mode configuration with my changes:
add admin-mac=[here was the mac address] auto-mac=no comment=defconf name=bridgeLocal
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode \
band=5ghz-onlyac disabled=no mode=ap-bridge ssid=MikroTik wmm-support=\
enabled
/ip hotspot profile
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
/interface wireless cap
set bridge=bridgeLocal discovery-interfaces=bridgeLocal enabled=yes \
interfaces=wlan2
/ip dhcp-client
add comment=defconf interface=bridgeLocal
/system clock
/system identity
set name=test-xl123
/tool romon
set enabled=yes
Config was exported by:
/ export hide-sensitive
Both devices were upgraded to 7.8 version of RouterOS and RouterBoard firmware.
Any suggestions?
