I have a hex s that I have configured to work with my network setup (two VLANs 100 and 200) and when connecting a node via a wired connection to any of the configured access ports, everything works as expected. Now I would like to configure my cap ax to provide two SSIDs and have them connect to each of the two VLANs respectively. However, I have not been able to figure out how to achieve this yet. The port the AP is connected to is configured as trunk port for both VLANs. I have recently reset the cap ax so it has the default configuration. What additional information can I provide to get to a working configuration?
Configure the eth1 (assuming that is the port you connect your cAP ax with) as trunk port (as well) and do VLAN filtering on the bridge. Then you are good to go.
For VLAN reference, please use this great tutorial:
Plus this ref: https://forum.mikrotik.com/viewtopic.php?t=182276
