I was hoping you could help me on understanding the burst mode in the queue tree.
actual-rate: current bandwidth speed
burst-limit: max speed
burst-threshold: on/off mark
Whenever having a short stream i.e. opening a website, the actual-rate fires up to the burst-limit for a few seconds. Then the burst will not be allowed as long as the average-rate is above the burst-threshold.
So when you have a bigger stream - let’s say you are downloading a software package - and the download rate is reaching its max-limit the whole time after the short burst, you won’t be able to achieve another burst until the stream ends and the actual-rate is getting lower, so the average-rate is getting below the burst-threshold.
If you are setting the burst-threshold above the max-limit the actual-rate will look like a sine wave and the burst will be allowed every few seconds depending on your average-rate.
Is this correct? Did I miss something?
Best wishes,
McShadow
