Hello ,
I’m trying to get my lte modem info
mikrotik.Send("/interface/lte/info");
mikrotik.Send("=number=0");
mikrotik.Send("=once");
mikrotik.Send("=.proplist=rssi", true);
but I get nothing - which is Ok because I don’t have rssi in info once
so my quesion is how can I run info for 5 seconds and then get the answer?
I have try to to this"
mikrotik.Send("=/quit");
but it say unknown parameter
so what is the right answer?
Thanks ,
mrz
2
number must point to either interface name or internal ID. 0 is not valid.
Internal id can be retrieved with
/interface/lte/print
=.proplist=.id
I get error - no such parameter
Console.WriteLine("Get LTE data : ");
mikrotik.Send("=number=lte1");
I understand why , it because in lte info on V6.36it doesn’t have rssi \ signal in this command
this is what i get if I run it once:
:put [/interface lte info lte1 as-value]
access-technology=Evolved 3G (LTE);current-cellid=466947;current-operator=;functio
nality=;imei=358178040979140;imsi=425030040235227;manufacturer=Sierra Wireless, In
corporated;model=MC7710;pin-status=;revision=SWI9200X_03.00.08.02AP R3715 CARMD-EN
-10526 2011/11/14 18:42:43;uicc=997250400002352274
my question is how can I run the info (not once) for 3 sec and then get the rssi ?
mrz
4
Also =once is not correct,
should be =once=
mikrotik.Send("=once=");
netflow
6
RSSI is visible in the log for me (Firmware 3.36, ROS 6.38.1)
