Getting on the box with telnet
Hello, I have a new routerboard unit and I’m trying to get on the box to configure it via telnet.
What telnet command should I enter to start the config dialog with the device?
thanks…Craig
telnet command from your windows?
Start -> RUN -> CMD
then
telnet 192.168.100.1
of course that should be the IP of your router, if you haven’t configured it already, there is no IP and telnet will not work, you will have to use Winbox MAC, like explained here: http://wiki.mikrotik.com/wiki/First_time_startup
Thank you! I’ll keep this as a reference. I was able to get on the device through winbox.
cheers…craig
granville, OH usa
