Hi tdw,
No the dns does not resolve to any valid ip for a given domain.
Also i reset the Mikrotik and tried using its default configuration and tried configuring as per your instruction.
Here are some of the outputs
Export before configuring
[admin@MikroTik] > export hide-sensitive
# jan/02/1970 00:03:27 by RouterOS 6.42.12
# software id = FNY8-7T22
# model = RB941-2nD
# serial number = A1C30AA95180
add admin-mac=74:4D:28:9E:92:02 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-9E9206 \
wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
export after configuring
# apr/14/2020 13:24:26 by RouterOS 6.42.12
# model = RB941-2nD
/interface wireless
set [ find default-name=ether1 ] mac-address=C0:25:E9:9E:DB:AF
/interface vlan
add interface=ether1 name=vlan-ether1-1885 vlan-id=1885
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan-ether1-1885 name=pppoe-out1 use-peer-dns=yes user=1725005306tho
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
/ip dns static
/tool mac-server
[admin@MikroTik] >
The moment i configure it and clone the MAC there is this change
while before configuring it was
So after adding the bridge interface using
i get two items in the /ip address option
I then remove the first using
/ip address remove number=0
The system then loses it ip address becomes 0.0.0.0 but upon restart the mikrotik router again hands out dhcp leases
Here is the output after address change
# apr/14/2020 19:34:38 by RouterOS 6.46.5
# model = RB941-2nD
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=20/40mhz-Ce country=no_country_set disabled=no distance=indoors frequency=auto \
frequency-mode=manual-txpower mode=ap-bridge ssid=MikroTik-9E9206 wireless-protocol=802.11
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full mac-address=C0:25:E9:9E:DB:AF
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/interface vlan
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dns static
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/system clock
set time-zone-name=Asia/Kolkata
/tool mac-server
[admin@MikroTik] >
So now at a loss as to what could be the issue. Is there and configuration issues at ISP end or am I missing some particular setting?
Is it possible for the PPPoE connection to be on the TPLink but configure a VPN client on the mikrotik so that the PC can connect via the VPN?
Thanks and regards
