Hi guys, I’ve just setup two 24 port CoudCore Routers as below, When I plug in to the ethernet locally they work fine but I can’t seem to connect to the routers over the fibre! Any ideas would be much appreciated.
Basically each has multiple Vlans and Interfaces with a bridge for each. I can connect to each routers local 10.0.4.0 addresses when plugged into Ether1 but I cannot hit the remote router!
Router 1:
add name="bridge1(default)"
add name="bridge2(Internet)"
add name="bridge3(Management)"
add name="bridge4(Main)"
set [ find default-name=ether24 ] name=ether24-Config
/interface vlan
add interface=sfp1 l2mtu=1584 name="vlan1(Default)" vlan-id=1
add interface=sfp1 l2mtu=1584 name="vlan2(Internet)" vlan-id=2
add interface=sfp1 l2mtu=1584 name="vlan3(Management)" vlan-id=3
add interface=sfp1 l2mtu=1584 name="vlan4(Main)" vlan-id=4
add bridge="bridge2(Internet)" interface="vlan2(Internet)"
add bridge="bridge1(default)" interface="vlan1(Default)"
add bridge="bridge3(Management)" interface="vlan3(Management)"
add bridge="bridge3(Management)" interface=ether24-Config
add bridge="bridge4(Main)" interface="vlan4(Main)"
add bridge="bridge4(Main)" interface=ether1
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-pppoe=yes \
use-ip-firewall-for-vlan=yes
add address=10.1.4.10/24 interface="bridge3(Management)" network=10.1.4.0
add address=10.0.4.10/24 interface="bridge4(Main)" network=10.0.4.0
add distance=1 gateway=10.0.4.9
/system identity
set name="Switch 1 (computer room)"
/system package update
set channel=current
/system routerboard settings
set protected-routerboot=disabled
/tool romon port
add
Router 2:
/interface vlan
add address=10.1.4.11/24 interface="bridge3(Management)" network=10.1.4.0
add address=10.0.4.11/24 interface="bridge4(Main)" network=10.0.4.0
/system identity
set name="Switch 2 (comms room)"
set channel=current
/tool romon port
add
Based on this post: http://wiki.mikrotik.com/wiki/Vlans_on_Mikrotik_environment
