Getting VRF trace route working
We constantly get asked by clients why they can not trace paths through VRF networks.
Lets explain a simple VPN site:
  add address=192.168.250.24 interface=lo			# OSPF router ID
  add address=10.0.0.2/30 interface=ether1			# LTE internet gateway
  add address=172.17.95.1/24 interface=ether2			# LAN
  add gateway=10.0.0.1						# Default gateway for router to establish VPN
/ip route vrf
  add interfaces=lo,vpn-hosting,ether2 routing-mark=mpls	# The VRF
If we direct everything to rfc1918 IPs, with exception of any local subnets, to the ‘mpls’ routing table we get traceroute working. It’s however fairly dangerous as any mistakes on the exception would result in the VPN not establishing and us loosing remote access to the router:
[davidh@Customer - Site 1] > /ip route rule print
Flags: X - disabled, I - inactive
 0   dst-address=10.0.0.0/30    action=lookup table=main	# Exempt internet breakout subnet
 1   dst-address=10.0.0.0/8     action=lookup table=mpls
 2   dst-address=172.16.0.0/12  action=lookup table=mpls
 3   dst-address=192.168.0.0/16 action=lookup table=mpls
The following is a sample working traceroute from a remote site:
[davidh@Customer - Site 2] > /tool traceroute 172.17.95.9 routing-table=mpls src-address=192.168.253.2
 # ADDRESS                          LOSS SENT    LAST     AVG    BEST   WORST
 1 192.168.253.1                      0%   42   9.1ms    13.8     6.4      31
 2 192.168.250.24                     0%   42   230ms   243.7   193.9   296.2
 3 172.17.95.9                        0%   42 230.9ms   242.1   188.7   343.5
The 2nd hop above is the router at Site 1 (192.168.250.24).
I would prefer to replace these routing rules with firewall rules but have an issue in that source NAT routes are not applied. I first removed the routing rules and loaded the following mangle firewall rules:
/ip firewall address-list
  add list=mpls address=10.0.0.0/8
  add list=mpls address=172.16.0.0/12
  add list=mpls address=192.168.0.0/16
/ip firewall mangle
  add chain=prerouting src-address-list=mpls protocol=icmp ttl=equal:1 action=mark-connection new-connection-mark=mpls passthrough=yes
  add chain=output connection-mark=mpls action=mark-routing new-routing-mark=mpls passthrough=yes
If I set the ‘output’ mangle rule to log, I observe the following:
13:49:36 firewall,info output: in:(unknown 0) out:ether1, proto ICMP (type 11, code 0), 10.0.0.2->192.168.253.2, len 56
13:49:37 firewall,info output: in:(unknown 0) out:ether1, proto ICMP (type 11, code 0), 10.0.0.2->192.168.253.2, len 56
13:49:38 firewall,info output: in:(unknown 0) out:ether1, proto ICMP (type 11, code 0), 10.0.0.2->192.168.253.2, len 56
13:49:39 firewall,info output: in:(unknown 0) out:ether1, proto ICMP (type 11, code 0), 10.0.0.2->192.168.253.2, len 56
13:49:40 firewall,info output: in:(unknown 0) out:ether1, proto ICMP (type 11, code 0), 10.0.0.2->192.168.253.2, len 56
13:49:41 firewall,info output: in:(unknown 0) out:ether1, proto ICMP (type 11, code 0), 10.0.0.2->192.168.253.2, len 56
13:49:42 firewall,info output: in:(unknown 0) out:ether1, proto ICMP (type 11, code 0), 10.0.0.2->192.168.253.2, len 56
13:49:43 firewall,info output: in:(unknown 0) out:ether1, proto ICMP (type 11, code 0), 10.0.0.2->192.168.253.2, len 56
Great, so far everything is actually working. ICMP packets with a TTL of 1 are tracked and corresponding output packets are identified by RouterOS. The trace route at the far end subsequently now shows the router as being 10.0.0.2 though:
 1 192.168.253.1                      0%   30  13.7ms    12.9       6    24.9
 2 10.0.0.2                           0%   30 237.7ms   262.7   198.9   343.7
 3 172.17.95.9                        0%   28 246.9ms   265.5   226.2   314.1
Okay, so then I simply want to set a source NAT rule on traffic leaving the vpn-hosting interface for packets from 10.0.0.2. None of the following rules however match:
  add chain=srcnat out-interface=vpn-hosting src-address=10.0.0.2 action=src-nat to-addresses=192.168.250.24
  add chain=srcnat connection-mark=mpls action=src-nat to-addresses=192.168.250.24
How does one source NAT traffic after using mangle to send the packet via a different routing table?
It appears that you must have the route from the source in the main routing table for mangle to work. Creating a loopback and setting the route via the loopback interface appears to work on initial testing.
