Ghest vlan to ISP2
Hello
I have 2 internet on RB3011 (ETH1 and ETH10), one (optic) is primary and second is wifi for backup
Also on Lan side have 4 vlans, one of vlans is vlan254 for ghest (192.168.254.0/24)
I want to route ghest vlan (254) to ISP2 (Wireless net). But can’t make it work. So ISP2 to be ised for all connected on vlan254.
add comment=Ghest disabled=no distance=1 gateway=“Wireless net” routing-mark=vlan254-routing
add check-gateway=ping distance=1 gateway=178.219.10.133
add distance=2 gateway=“Wireless net”
add comment=“Centrala Data” distance=1 dst-address=192.168.3.0/24 gateway=“SPAJZ Centrala”
add comment=“Centrala CCTV” distance=1 dst-address=192.168.37.0/24 gateway=“SPAJZ Centrala”
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward dst-address=192.168.5.0/24 src-address=192.168.254.0/24
add action=drop chain=input dst-address=192.168.5.0/24 src-address=192.168.254.0/24
/ip firewall mangle
add action=mark-packet chain=prerouting in-interface=vlan254 new-packet-mark=upload-vlan254 passthrough=yes
add action=mark-packet chain=prerouting in-interface=ether10 new-packet-mark=download-vlan254 passthrough=yes
add action=mark-routing chain=prerouting new-routing-mark=vlan254-routing packet-mark=upload-vlan254 passthrough=yes
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=WAN
add action=src-nat chain=srcnat dst-address=192.168.3.0/24 ipsec-policy=out,none out-interface-list=WAN src-address=192.168.5.0/24 to-addresses=13.0.0.2
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface=“VPN Securitron”
add action=dst-nat chain=dstnat dst-port=8000 in-interface=ether1 protocol=udp to-addresses=192.168.5.251 to-ports=8000
add action=dst-nat chain=dstnat dst-port=8000 in-interface=ether1 protocol=tcp to-addresses=192.168.5.251 to-ports=8000
add action=dst-nat chain=dstnat dst-port=8001 in-interface=ether1 protocol=udp to-addresses=192.168.5.252 to-ports=8000
add action=dst-nat chain=dstnat dst-port=8001 in-interface=ether1 protocol=tcp to-addresses=192.168.5.252 to-ports=8000
add comment=defconf name=WAN
add comment=defconf name=LAN
add interface=vlan30 list=LAN
add interface=ether1 list=WAN
add interface=ether10 list=WAN
wHAT IS THE PROBLEM ?
Stuff I cant explain???
One part that confuses me is routes for private IPs… are these for VPN connections…
add comment=“Centrala CCTV” distance=1 dst-address=192.168.37.0/24 gateway="SPAJZ Centrala
Also not sure of the purpose of this sourcenat rule.. probably also to do with VPNs??
As for the routing issue,
This can be done without any MANGLING and thus fastrack can be re-enabled as well.
add check-gateway=ping distance=1 gateway=178.xxx.yy.m.bb
add comment=Ghest disabled=no distance=2 gateway=“Wireless net” routing-mark=UseWIFI-ISP
Route Rule.
source address = subnet of vlan
OR
interface = vlan254
Action: Lookup Only in Table ****
Table = =UseWIFI-ISP
***** In this scenario guest wifi users will only use ISP2, if ISP 2 is not available they will not be switched to ISP1
If you wanted them to use ISP1 as a backup, then use ACTION = LOOKUP
why are not all you vlans listed here ???
interface list member
Your Firewall rules need help as well…
Still can’t make it work. I disable MANGLE, both internet works, all ghest have IP from 192.168.254.0/24
Can you write full cli line by line so all vlan254 (192.168.254.0/24) be routed to ISP2 (eth10)
P.S.
Yes,that routes are for IPIP made by ISP1…
Show me your FULL config so I can see what you may have done incorrectly, showing only parts does not help.
and dont forget to use code tags at the start and stop of the text file after you have pasted it here.
the code tags are the white square brackets in the black square to the right of the B I and U symbols on the top of these text boxes when making/editing a post
/caps-man channel
add band=2ghz-g/n name=“Auto 2,4GHz”
add band=5ghz-a/n/ac name=“Auto 5GHz”
add admin-mac=C4:AD:34:85:10:A5 auto-mac=no fast-forward=no name=bridge
vlan-filtering=yes
set [ find default-name=ether1 ] comment=“Internet Orion (Optika)”
set [ find default-name=ether10 ] comment=“Wireless Internet (Backup)”
set [ find default-name=sfp1 ] comment=“TRUNK Cisco”
/interface pppoe-client
add disabled=no interface=ether10 name=“Wireless net” user=spajz
/interface ipip
add local-address=178.219.10.134 name=“SPAJZ Centrala” remote-address=
95.140.124.94
/interface vlan
add comment=Data interface=bridge name=vlan10 vlan-id=10
add comment=Voip interface=bridge name=vlan20 vlan-id=20
add comment=Management+Securitry interface=bridge name=vlan30 vlan-id=30
add comment=Gosti interface=bridge name=vlan254 vlan-id=254
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes local-forwarding=yes name=
Firma vlan-id=10 vlan-mode=use-tag
add bridge=bridge name=Gosti vlan-id=254 vlan-mode=use-tag
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm
group-encryption=aes-ccm name=Gosti
group-encryption=aes-ccm name=Firma
/caps-man configuration
add channel=“Auto 2,4GHz” country=serbia datapath=Firma mode=ap name=
“Firma 2,4GHz” security=Firma ssid=“SPAJZ D.O.O. 2,4GHz”
add channel=“Auto 2,4GHz” country=serbia datapath=Gosti mode=ap name=Gosti
security=Gosti ssid=Gosti
add channel=“Auto 5GHz” country=serbia datapath=Firma mode=ap name=
“Firma 5GHz” security=Firma ssid=“SPAJZ D.O.O. 5GHz”
add name=dhcp_pool0 ranges=192.168.5.50-192.168.5.200
add name=dhcp_pool1 ranges=192.168.20.50-192.168.20.150
add name=dhcp_pool2 ranges=192.168.33.50-192.168.33.100
add name=dhcp_pool3 ranges=192.168.254.2-192.168.254.254
add add-arp=yes address-pool=dhcp_pool0 disabled=no interface=vlan10
lease-time=1d name=Data
add add-arp=yes address-pool=dhcp_pool1 disabled=no interface=vlan20
lease-time=1d name=VoIP
add add-arp=yes address-pool=dhcp_pool2 disabled=no interface=vlan30
lease-time=1d name=Security+Management
add add-arp=yes address-pool=dhcp_pool3 disabled=no interface=vlan254
lease-time=1d name=Gosti
/interface sstp-client
add connect-to=securitron.dyndns-work.com disabled=no name=“VPN Securitron”
profile=default-encryption user=Spajz_VelikiMagacin
/queue tree
add comment=Gosti max-limit=10M name=download packet-mark=download-vlan254
parent=vlan254 queue=pcq-download-default
add comment=Gosti max-limit=5M name=upload packet-mark=upload-vlan254 parent=
vlan254 queue=pcq-upload-default
/snmp community
add addresses=10.20.20.0/24 authentication-protocol=SHA1 name=private
security=private write-access=yes
/system logging action
add name=Remote remote=10.20.20.254 target=remote
/user group
set full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas
sword,web,sniff,sensitive,api,romon,dude,tikapp”
/caps-man access-list
add action=accept allow-signal-out-of-range=10s disabled=no interface=any
signal-range=-78..120 ssid-regexp=“”
add action=reject allow-signal-out-of-range=10s disabled=no interface=any
signal-range=-120..-79 ssid-regexp=“”
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man manager interface
add disabled=no interface=vlan30
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=
“Firma 2,4GHz” name-format=identity slave-configurations=Gosti
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=
“Firma 5GHz” name-format=identity
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged
ingress-filtering=yes interface=ether2 pvid=10
ingress-filtering=yes interface=ether3 pvid=10
ingress-filtering=yes interface=ether4 pvid=10
ingress-filtering=yes interface=ether5 pvid=10
ingress-filtering=yes interface=ether6 pvid=10
ingress-filtering=yes interface=ether7 pvid=10
ingress-filtering=yes interface=ether8 pvid=30
add bridge=bridge frame-types=admit-only-vlan-tagged ingress-filtering=yes
interface=sfp1
/interface bridge vlan
add bridge=bridge tagged=sfp1,bridge untagged=
ether2,ether3,ether4,ether5,ether6,ether7 vlan-ids=10
add bridge=bridge tagged=bridge,sfp1 untagged=ether8 vlan-ids=30
add bridge=bridge tagged=sfp1,bridge vlan-ids=20
add bridge=bridge tagged=sfp1,bridge vlan-ids=254
/interface detect-internet
set internet-interface-list=WAN lan-interface-list=LAN wan-interface-list=WAN
add interface=vlan10 list=LAN
add interface=vlan20 list=LAN
add interface=vlan254 list=LAN
add address=192.168.33.1/24 interface=vlan30 network=192.168.33.0
add address=192.168.5.1/24 interface=vlan10 network=192.168.5.0
add address=192.168.20.1/24 interface=vlan20 network=192.168.20.0
add address=192.168.254.1/24 interface=vlan254 network=192.168.254.0
add address=178.219.10.134/30 interface=ether1 network=178.219.10.132
add address=13.0.0.2/30 interface=“SPAJZ Centrala” network=13.0.0.0
/ip cloud
set update-time=no
add address=192.168.5.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.5.1
add address=192.168.20.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.20.1
add address=192.168.33.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.33.1
add address=192.168.254.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.254.1
set servers=8.8.8.8,8.8.4.4
invalid
192.168.254.0/24
192.168.254.0/24
/ip firewall mangle
WAN
add action=src-nat chain=srcnat disabled=yes dst-address=192.168.3.0/24
“VPN Securitron”
add comment=Gosti disabled=yes distance=2 gateway=“Wireless net”
routing-mark=ISP2
“SPAJZ Centrala”
“SPAJZ Centrala”
/ip route rule
add action=lookup-only-in-table disabled=yes interface=vlan254 table=ISP2
/ip service
set telnet disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip smb
set allow-guests=no interfaces=vlan30
/ip upnp
set show-dummy-rule=no
/lcd
set backlight-timeout=never default-screen=interfaces
/lcd pin
set pin-number=1910
/snmp
set contact=“Milan Rankovic” enabled=yes location=
“Spajz Veliki Magacin/Ruter” trap-community=private trap-generators=
interfaces,start-trap,temp-exception trap-interfaces=all trap-target=
10.20.20.254 trap-version=3
/system clock
set time-zone-name=Europe/Belgrade
/system identity
set name=“Ruter Spajz Magacin 7000”
/system logging
add action=Remote prefix=Spajz_Veliki_Magacin-Ruter topics=critical
add action=Remote prefix=Spajz_Veliki_Magacin-Ruter topics=error
/system note
set note=“###########################################################
\n# S E C U R I T R O N #
\n# Dobrodosli u CLI #
\n# #
\n# SVE KONEKCIJE SU PRACENE I SNIMLJENE #
\n# Diskonektujte se ODMAH ako niste autorizovan korisnik! #
\n# #
\n# support: > NEMANJA@SECURITRON.RS > #
\n###########################################################”
/system ntp client
set enabled=yes primary-ntp=162.159.200.123
/system scheduler
add interval=1w name=“FTP Remote Backup enscripted” on-event=
“FTP Remote Backup enscripted” policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
start-date=aug/09/2020 start-time=03:00:00
add interval=15m name=“DynuDNS update” on-event=“DynuDNS update” policy=
start-date=aug/10/2021 start-time=17:24:53
/system script
add dont-require-permissions=yes name=“FTP Remote Backup enscripted” owner=
nemke policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=“#
_Script for backup of device data\r
\n\r
\n:global ime;\r
\n:global ver;\r
\n:global full;\r
\n:global path;\r
\n:set ime "$[/system identity get name]";\r
\n:set ver "$[/system package get number=0 version]";\r
\n:set full "$ime-$ver.backup";\r
\n:set path "/Backup/Uredjaji/Network/Spajz/Magacin7000/$full";\r
\n\r
\n# Create Backup file\r
\n/system backup save encryption=aes-sha256 name="$ime-$ver" password=
Mephisto1910\r
\n\r
\n:log info " Local Backup Created Successfully"\r
\n\r
\n# delay time to finish the create \r
\n:delay 10s\r
\n\r
\n# Upload backup file to FTP server.\r
\n\r
\n/tool fetch address=10.20.20.254 src-path="$ime-$ver.backup" \\r
\nuser=mikrotik mode=ftp password=mikrotik1910 \\r
\ndst-path=$path upload=yes port=21\r
\n\r
\n:log info "Backup Uploaded Successfully"\r
\n\r
\n# delay time to finish the upload\r
\n:delay 10s\r
\n\r
\n# Delete created backup files once they have been uploaded\r
\n# So they don’t accumulate and fill up storage space on the router\r
\n\r
\n/file remove [find name~".backup"]\r
\n\r
\n:log info "Local Backup File Deleted Successfully"”
add dont-require-permissions=yes name=“DynuDNS update” owner=nemke policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=“/
tool fetch url="> https://api.dynu.com/nic/update\?username=amurabe&hostn>
ame=spajzmagacin7000.dynuddns.com&password=34564024978dc5bbe824e27b6dd15c7
928f8ce65c22f3837895e589807af0882"”
/tool bandwidth-server
set authenticate=no enabled=no
/tool graphing interface
add allow-address=10.20.20.0/24
/tool graphing queue
/tool graphing resource
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
/tool romon port
Its been like forever, I grew a beard, while waiting :slight_smile:
I will a have a look at the config, confession capsman I know nothing about.
(1) You could remove all the vlan members of the lan and just use the bridge
add interface=bridge list=LAN
(2) Your PPPOE name has to be on the WAN interface members list.
add interface=Wireless Internet list=WAN
(3) WARNING! You are missing a defaut firewall rule that protects ones Router on the input chain!
invalid
add action=drop chain=input in-interface-list=!LAN
(4) Unless using the MT app, I would set these to none.
(5) You can set this rule to NONE.
/tool mac-server
(6) Now to look at your bridge and vlan settings!!
{bridgeports}
a. it looks like you are sending VLAN10 to etherports 2-7 as access ports to dumb devices!
b. it looks like you are sending VLAN30 to etherport 8 as an access port to a dumb device
c. it looks like your sending a bunch of vlans to SFP1 as a trunk port to a smart device that can read vlan tags
{vlan filtering}
d. nicely done, confirms the above…
Other recommendations:
(7) Forward firewall chain…
Change this one rule that tries to do two things but is actually inefficient once one starts changing the config with additional requirements!
To this!
add action=allow chain=forward comment=“Allow Port Forwarding” connection-nat-state**=dstnat** connection-state=new in-interface-list=WAN
add action=drop chain=forward comment=“drop all else”
This accomplishes all the initial rule did plus more!
a. it still allows port forwarding as an allow rule by itself, so its clearer and if one didnt need port forwarding they could disable or remove it.
b. it stops all wan to lan traffic like the initial rule BUT BUT also stops all LAN to WAN and LAN to LAN traffic. *****
***** So now you should realize two things.
i. You no longer need rules to block traffic between vlans/subnets, it is already accomplished, so you can get rid of these two rules no longer needed:
192.168.254.0/24
192.168.254.0/24
ii. The last drop all rule also stop internet access so to enable it (and if all the vlans need it then its simple)
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN
If, for example you only wanted 3/4 vlans to get internet what I would do is create another interface list call ie Allow-Net
add interface=vlanXX list=Allow-Net
add interface=vlanYY list=Allow-Net
add interface=vlanzz list=Allow-Net
iii. If you, as admin, are on the management net .254 and want to be able to access all VLANs from that net then you will need to add before the drop all last rule …
add action=accept chain=forward in-interface=vlan254 out-interface-list=LAN
(8) Lastly speaking about management net, I am not sure of its purpose.
but right now with the default rules everybody on the LAN can access the router adn that generally is a bad practice.
Suggesting that you narrow that down to at least the management net IF that is where you will want to be able to access the router from.
Often as admin you may log into any vlan at any point in time and from there want to be able to log into the router.
So you need to state the requirements clearly and then I can help you set that up so it makes sense.
All thing I done. In meantime I add this rules
But there is same problem with routing vlan256 (ghuest) to ISP2 (Wireless),how to do it.
Okay, then repost the config so I am working with the exact config you have now…
vlan-filtering=yes
/interface ipip
95.140.124.94
/interface vlan
/caps-man datapath
/caps-man security
/queue tree
/snmp community
/user group
/caps-man manager
interface=sfp1
add interface=“Wireless net” list=WAN
/ip cloud
set update-time=no
invalid
192.168.254.0/24
192.168.254.0/24
/ip firewall mangle
WAN
“VPN Securitron”
routing-mark=ISP2
“SPAJZ Centrala”
“SPAJZ Centrala”
/ip route rule
/ip service
/ip smb
/ip upnp
/lcd
/lcd pin
set pin-number=1910
/snmp
/system clock
/system identity
/system logging
/system ntp client
/system scheduler
/system script
nemke policy=
\n\r
\n:global ime;\r
\n:global ver;\r
\n:global full;\r
\n:global path;\r
\n\r
Mephisto1910\r
\n\r
\n\r
\n:delay 10s\r
\n\r
\n\r
\n\r
\n\r
\n:delay 10s\r
\n\r
\n\r
\n\r
tool fetch url="https://api.dynu.com/nic/update\?username=amurabe&hostn
928f8ce65c22f3837895e589807af0882" keep-result=no”
/tool mac-server
/tool romon
set enabled=yes
/tool romon port
You forgot the item I highlighted in bright colours on input chain of firewall ???
Why are you using mangle rules these ones??
/ip firewall mangle
Should be enabled!
routing-mark=ISP2
“SPAJZ Centrala”
“SPAJZ Centrala”
/ip route rule
