I seem to have ghost entries in the config which I'm unable to remove, I've tried 'remove [ find "various options"]' and webfig
[admin@RouterOS] /ip/route> ex
**add check-gateway=ping disabled=no distance=1 dst-address="" gateway=8.8.4.4 routing-table=401 scope=12 suppress-hw-offload=no
add check-gateway=ping disabled=no distance=1 dst-address="" gateway=8.8.8.8 routing-table=400 scope=12 suppress-hw-offload=no
add check-gateway=ping disabled=no distance=1 dst-address="" gateway=8.8.8.8 routing-table=main suppress-hw-offload=no
add check-gateway=ping disabled=no distance=2 dst-address="" gateway=8.8.4.4 routing-table=main suppress-hw-offload=no
add check-gateway=ping disabled=no distance=5 dst-address=0.0.0.0/0 gateway=192.168.0.254 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=1.1.1.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=32
add disabled=no distance=1 dst-address=1.1.1.1/32 gateway=192.168.8.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=31
add disabled=no distance=1 dst-address=8.8.8.8/32 gateway=192.168.0.254 pref-src="" routing-table=to_ISP2 scope=30 suppress-hw-offload=no target-scope=31
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=8.8.8.8 pref-src="" routing-table=to_ISP2 scope=30 suppress-hw-offload=no target-scope=32
add disabled=no distance=5 dst-address=0.0.0.0/0 gateway=192.168.8.1 routing-table=main suppress-hw-offload=no
[admin@RouterOS] /ip/route> print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, s - STATIC; + - ECMP
Columns: DST-ADDRESS, GATEWAY, DISTANCE
DST-ADDRESS GATEWAY DISTANCE
0 s 0.0.0.0/0 192.168.8.1 5
1 s 0.0.0.0/0 192.168.0.254 5
2 As 0.0.0.0/0 1.1.1.1 1
3 As 1.1.1.1/32 192.168.8.1 1
DAc 192.168.0.0/24 ether2 0
DAc 192.168.1.0/24 bridge 0
DAc 192.168.2.0/24 vlan2 0
DAc 192.168.3.0/24 vlan3 0
DAc 192.168.4.0/24 vlan4 0
DAc 192.168.8.0/24 ether1 0
4 As+ 0.0.0.0/0 8.8.8.8 1
5 As 8.8.8.8/32 192.168.0.254 1
