Ghost in HotSpot network
Hey, we got problem with ghost in a students network,which is a HotSpot.
We want to have ghost running without to have the computers logged in.
Ghost uses multicast to make an installation of a whole network in minutes. Is it possible to run those multicast without having to turn of the HotSpot?
Does anyone have any experiance of multicast HotSpot network at all?
Regards, Paul
I have to mention that the HotSpot is a bridge with two interfaces one EoIP and one bonding of two physical interfaces.
hello,
try to add ghost server IP to allowed IPs
in /ip hotspot ip-binding section.
This will allow communication between workstations and server.
In addition to this, check on which port ghost communicate,
and create rule, that allows communication on this port in both directions.
regards,
Stoned.
I have allready tried adding the MAC to be logged in automatic.
I think this will do the same as adding theIP.
The problem with this is that the rules from HotSpot puts in before other rules when it restarts.
I think it got something to do with the bonding and bridging.
Any suggestions?
/Paul
In Hotspot - IP Bindings put only the IP in Address and select bypassed… may work
Regards!
Alessio
