without auto negotiation the link is in “forced up” mode. that does not mean, the link is actually up. the thing is, that they are still not able to communicate with each other. the led is only lit cause you did not disable the port itself.
regarding 10/100/1000BaseT operation with copper SFPs:
this is something, that not every implementation support. copper SFPs, like cisco’s GLC-T were first used in platforms which did only support 1000BaseT full duplex operation. that means no ordinary 10/100 device was able to talk with them.
i have an rb2011LS with a GLC-T inserted in it’s SFP slot. the other side is a cisco eurodocsis3.0 modem with 10/100/1000BaseT support. they work together perfectly. but the mikrotik is only advertising 1000BaseT full-duplex, so the modem is only able to agree on that.
[xxx@rb2011] /interface ethernet> monitor uplink
status: link-ok
auto-negotiation: done
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
advertising:
link-partner-advertising:
sfp-rx-lose: no
strangely i don’t see any kind of parameters in printouts that work very well for built-in ethernet ports.
[xxx@rb2011] /interface ethernet> monitor ether2
;;; server
status: link-ok
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
advertising: 10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
link-partner-advertising: 10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
or on other platforms, like the crs125. btw, both devices are running 6.30.1.
probably the RB2011 does not have SFF8472 compliant DDM support.
[xxx@crs125] /interface ethernet> monitor sfp1
;;; uplink
status: link-ok
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
advertising:
sfp-module-present: yes
sfp-rx-lose: no
sfp-connector-type: (unknown)
sfp-link-length-copper: 100m
sfp-vendor-name: Mikrotik
sfp-vendor-part-number: S-RJ01
sfp-vendor-serial: MT31126H2376
sfp-manufacturing-date: 13-12-14
sfp-wavelength: 65535nm
