Which Gigabit FX PCI supports RouterOS, and are there any known issues with that kind of hardware and RouterOS?
Regards
Faton
Regards
Faton
Some of the intel fiber boards work…
Check the supported list on the WIKI…
I have one loaded, I just cant see it as the unit is running…
hold on…
8254GC chipset from Intel (Newer board) loads and works fine under 3.16..
Hope this helps..
Can you give me the exact model number of your interface that you are using.
Regards.
Faton
Hold on… I will bring the router off line…
OK…
A38888-002
There are listing on ebay…
Have a good one !!
Thanks a lot, I’ve got it.
Regards
Faton
