Gigabit POE RB260GSP vs hEX PoE lite, what is what?
I do not understand why would have to buy a Gigabit POE Swith for $ 55.95, if you can buy the router for $ 59.95?
Where is the trick? -if swith to the operating temperature is lower, while energy consumption higher. Where are the pros?
Hex POE Lite is only FE not GB
Hex POE will be GB but not released !
Mistry7
Just because it’s a router doesn’t mean you will be using it for “routing”. Many people use the hex Poe Lite for a capsman server, works great. The rb260gsp can’t run full RouterOS so it cannot run capsman.
Thanks for the reply, I realized that we made a mistake Routers purchased :open_mouth: .
It’s also because MikroTik their specifications and brochures do not show whether it is 100 Mbps or 1000 Mbps :frowning: , but the seller has made a mistake in the description indicates that it is a Gigabit
They do inform.
http://routerboard.com/RB750UPr2
“10/100 Ethernet ports 5”
http://routerboard.com/RB260GSP
“10/100/1000 Ethernet ports 5”
Uh, yes, thanks, finally I see (and only using “Ctrl + F”)!
Now you know the “pattern” they use for specifications
http://routerboard.com/RB2011UiAS-RM
"10/100 Ethernet ports 5
10/100/1000 Ethernet ports 5 "
Details for Mikroitk’s naming convention you can find here: http://wiki.mikrotik.com/wiki/Manual:Product_Naming
