You can assign as many subnets/IP addresses to any interface that you want, and the RouterBoard will handle routing between them fine. However you do not ever want to run two different DHCP servers on the same interface. You need some form of separation, weather it be by physical interface or VLANs. By having two different DHCP servers on the same layer2 network you are asking for tons of problems, and it will be a complete crap shoot as to which one will the client will listen to.
so now wht can i do i have to i386 1 is running Mikrotik 4.2 & other one is Mikrotik 3.22
so now on Mikrotik 3.22 have a dhcp-server having subnet 192.168.80.0/20
& mikrotik 4.2 have also dhcp-server having subnet 192.168.100.0/24
now i have a 2 media server which is get ip from mikrotik 3.22 my problem is that the users of mikrotik 4.2 which is getting ip from 192.168.100.0/24 subnet they can’t access 192.168.80.0/20 subnet media server…
I would need a network diagram to be more helpful in this case, but I’m guessing you’ll need to put in a route on the 192.168.100.0/24 router so it knows how to get to 192.168.80.0/20
