Give priority to an IP address
I have a VOIP server (e.g. 192.168.5.1) on ether3, and I want outbound traffic from that host to get priority over ANY other traffic to ensure call quality.
I have looked at the docs but still not sure the best way to implement this.
What do you recommend? and please give me examples of syntax I need to enter
Thanks again
see queue tree in manual (under bandwidth management) and also packet marking
I used simple priority and works ok. Here I copy a config from one rb133 working:
The ip network 192.168.27.0 is the customers, an the 192.168.198.1 is the ip of the phone server.
The queue number 0 is for internet and has lower priority than telephony. Also has a lower band restriction.
hope this help you.
[admin@mikrotik] > queue simple print
0 name=“INTERNET” target-addresses=x.x.x.x/29 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8
queue=default-small/default-small limit-at=0/0 max-limit=256000/256000 burst-limit=512000/512000
burst-threshold=512000/512000 burst-time=1s/1s total-queue=default-small
1 name=“TELEFONIA” target-addresses=192.168.27.0/24 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=1
queue=default-small/default-small limit-at=0/0 max-limit=1000000/1000000 total-queue=default-small
2 name=“TELEFONIA2” target-addresses=192.168.198.1/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=1
[admin@mikrotik] >
