give users cached squid files at full speed
ok so i am configuring my squid box to cache files that are large in size. for example, .exe, .dmg, .ipa and so on.
the only problem is the mikrotik router downloads these files to the user at regular speeds.
since they are from my local network i need them to be at full speeds.
can we set a rule that since these files are from the squid cache squid server they should go to the user at full speed rather than the limited speed?
Following article will describe the process to bypass the CACHED contents from Mikrotik queue.
http://aacable.wordpress.com/2011/07/21/mikrotik-with-squidzph-unlimited-speed-for-cache-content-traffic/
thanks, i actually referred back to your guide and it worked wonderfully.
except not for pppoe users.
The method works fine regardless of client types. There must be something else wrong with your config.
