:global fileCount [:len [/file find ]]
hi im looking for a script that will monitor the amount of files in file
what i need it to do is count the files so if there is 200 files in the file list is will disable the script logs
can any one help me with this
Try
/file print count-only
but how can i put this in a script
:global fileCount [/file print count-only]
how can i set a script from1 rb to another to move file number 1 and when its dont to del that file?
rb1 connects to rb 2 and copys file number 1 then del it
