global variable defconfMode
After an upgrade to 7.10 or 7.10.1 (not sure) i have a global variable called defconfMode.
[peter@RBR-001] /system/script/environment> pr
Columns: NAME, VALUE
NAME VALUE
0 ddnsPreviousIp 178.xxx.xxx.xxx
1 defconfMode
What is it and why is it there, is it there by the hand of Mikrotik?
This is on a hEX S.
I upgraded two hAP aC routers, to 7.10.1, that do not have this global variable.
You can ignore this for now, it is defconf script leftover by mistake.
Thanks!
cAPax upgrade 7.20.8 -> 7.21.5 ... this "defconfMode" variable has also been left over here
