Global variable not retained in script
hi,
I am new to mikrotik scripting, and trying to create a global variable that will persists throughout the mikrotik. I know global-variables are user-based, so I only use Admin in this case. Here is my script :
/log info message="gIsReconnecting before: $gIsReconnecting"
:if ( $gIsReconnecting = nil ) do= {
  /log info message="gIsReconnecting is empty"
  :global gIsReconnecting "yellow"
  :set gIsReconnecting "RED"
/log info message="gIsReconnecting after:  $gIsReconnecting"
Output (after running a few times) :
Problem is the global variable is never set. Am I doing something wrong ?
You need to declare global variable at the top of the script, or else it does not work.
I did just post the same answer yesterday:
http://forum.mikrotik.com/t/script-contents-run-manually-but-not-from-run-script-button/147148/1
Thanks! I read https://wiki.mikrotik.com/wiki/Manual:Scripting and it doesn’t say global variables needs to be right on top. The closest is “Every variable, except for built in RouterOS variables, must be declared before usage by local or global keywords. ..
On a note to help other users, global variables must always be declared on top the script. Here’s an example of how i am using a global variable throughout the device :
Script called when mikrotik device startup (i use System->Scheduler to run a script @ startup)
#in System->Scheduler->On Event :
/system script run setGlobal
Then, the script called ‘setGlobal’ is as such :
#in System->Scripts->new script name 'setGlobal'
:global gIsReconnecting "Y"
/log info message="gIsReconnecting: $gIsReconnecting "
Subsequent scripts called must have all variables declared on top as such :
#code
#code...
