Global Variables are not global ?
3.0rc9
Within a script:
:global temp 123
and then try to recover this value from terminal:
:env print
Show’s nothing. Is it really true that global variables are now only global within that script ? This is bad… I really need a global variable that works across the entire router. What happened …
What you tried works for me.
The only caveat I found was going the other way. If I had a global variable and I needed to get it into a script, I would have to redeclare it like so.
:global temp $temp
It would then get the global variable and update it when changed in the script.
