GNS3 + Mikrotik = no wlan
There is an issue with my wlan on Virtual mikrotik.
I use the VMware Workstation 12 Player, GNS 2.1.3 and different mikrotik’s versions (since 6.37.x till 6.42.x)- a free license.
I can’t find a wlan interface on either of mikrotiks. I can’t even see a possibility to add it. The only one communicate I see is red coloured: “master-interfaces: uknown”
Do you have any ideas or sugestions, what could go wrong?
I’m not sure if it’s important but I don’t have a gns3-internet connection, cause there is probably a problem with my virtual network cards
I think wireless is not supported on CHR, i never seen it. And i think GNS3 doesn’t supports wireless links too.
@up:
Thanks :frowning:
