GoDaddy Dynamic DNS
New to Mikrotik scripting and looking for help. I have a PowerShell script I want to convert to a Mikrotik script. The script is to update IP for GoDaddy hosted domain. I’d like to pull the IP address from the interface rather then an external site.
$domain = 'your.domain.to.update'  # your domain
$name = 'name_of_host' #name of the A record to update
$key = 'key' #key for godaddy developer API
$secret = 'Secret' #Secret for godday developer API
$headers = @{}
$headers["Authorization"] = 'sso-key ' + $key + ':' + $secret
$result = Invoke-WebRequest https://api.godaddy.com/v1/domains/$domain/records/A/$name -method get -headers $headers
$content = ConvertFrom-Json $result.content
$dnsIp = $content.data
# Get public ip address there are several websites that can do this.
$currentIp = Invoke-RestMethod http://ipinfo.io/json | Select -exp ip
if ( $currentIp -ne $dnsIp) {
    $Request = @{ttl=3600;data=$currentIp }
    $JSON = Convertto-Json $request
    Invoke-WebRequest https://api.godaddy.com/v1/domains/$domain/records/A/$name -method put -headers $headers -Body $json -ContentType "application/json"
Alternatively here it is as a bash script
domain=""   # your domain
name=""     # name of A record to update
key=""      # key for godaddy developer API
secret=""   # secret for godaddy developer API
headers="Authorization: sso-key $key:$secret"
# echo $headers
result=$(curl -s -X GET -H "$headers" \
 "https://api.godaddy.com/v1/domains/$domain/records/A/$name")
dnsIp=$(echo $result | grep -oE "\b([0-9]{1,3}\.){3}[0-9]{1,3}\b")
# echo "dnsIp:" $dnsIp
ret=$(curl -s GET "http://ipinfo.io/json")
currentIp=$(echo $ret | grep -oE "\b([0-9]{1,3}\.){3}[0-9]{1,3}\b")
# echo "currentIp:" $currentIp
 if [ $dnsIp != $currentIp ];
 then
#	echo "Ips are not equal"
	request='{"data":"'$currentIp'","ttl":3600}'
#	echo $request
	nresult=$(curl -i -s -X PUT \
 -H "$headers" \
 -H "Content-Type: application/json" \
 -d $request "https://api.godaddy.com/v1/domains/$domain/records/A/$name")
#	echo $nresult
fi
will using the following syntax use the variables?
:local headers “Authorization: sso-key $usrkey:$usrsecret
Does anyone know a way to send a custom header like the -H function for curl using Mikrotik Fetch tool?
Found DomainConnect DDNS that’ll run on local machines as it appears MikroTik Fetch tool doesn’t yet support editing headers which is required for authentication with GoDaddy api. I have written everything for Mikrotik so hopefully when header editing is added I can add the necessary commands.
I write a script to update DDNS
https://gist.github.com/nansenat16/bbedb728a486b4a7fb76ae031995a317
Thank you nansenat16 for the example. I see that since 6.44 http-header-field has been added. I had been busy correcting issues with the 6.44.x updates that I haven’t noticed the fetch changes.
Any update on this? I have a couple godaddy domains i’d like my tik to auto update to.
Have you thought about using the .sn.mynetname.net built into the OS under IP > Cloud?
For instance if you own stuff.net as a godaddy (ugh!) domain and wanted omaha.stuff.net to resolve to your router’s wan - you use Mikrotik’s built in myname.net address as a cname target.
Let’s say yours is 830708af0128.sn.myname.net – you then create a cname for omaha.stuff.net and point it to 830708af0128.sn.myname.net. It’s what I’ve been doing for a while now – works with any DNS provider, even one that doesn’t natively support DDNS entries and updating. I have not as of yet had a problem with it. If you replace the router – you have a new mac/address - you just update your cname entry to the new one. If you change DNS provider – it’s a simple move – no client change.
I’ve updated the script posted above to a simpler logic where the current IP is fetched from a public IP service and updated accordingly:
#GoDaddy DDNS Update Script
#Tested with RouterOS 6.45.2 (Minimum version RouterOS 6.44)
#Date:2020/10/12
#The script requires "read,write,policy,test" policies to work with global variables.
#Create Schedule running
# /system scheduler add name=update-ddns interval=10m on-event=godaddy-ddns
:local Domain "Domain"
:local Hostname "Hostname"
:local APIKey "GoDaddy Key"
:local APISecret "GoDaddy Secret"
# DDNS Params
:local ddnsURL "https://api.godaddy.com/v1/domains/$Domain/records/A/$Hostname"
# Get current IP
:global currentIP
:local IPGetURL "https://ipecho.net/plain"
:local result [/tool fetch url=$IPGetURL http-method=get as-value output=user]
:if ($result->"status" = "finished") do={
    :set currentIP ($result->"data")
} else={
    :log error ("DDNS: Error getting current IP from $IPGetURL")
    :err "Error getting current IP"
#Store global variable to check if update is required
:global lastConfiguredIP
:if ([:typeof [:global lastConfiguredIP]] = nil ) do={ :global lastConfiguredIP 0.0.0.0 } else={ :set lastConfiguredIP $lastConfiguredIP }
:if ($currentIP != $lastConfiguredIP) do={
    :log info "DDNS: Updating $Hostname.$Domain to use IP: $currentIP"
    :local ddnsipjson "[{\"type\":\"A\", \"name\":\"$Hostname\", \"data\":\"$currentIP\", \"ttl\":3600}]"
    :local result [/tool fetch url=$ddnsURL http-method=put http-data=$ddnsipjson http-header-field="content-type: application/json,Authorization: sso-key $APIKey:$APISecret" as-value output=user]
        :log info ("DDNS: Configured domain $Hostname.$Domain to IP $currentIP.")
        :global lastConfiguredIP $currentIP
    } else={
        :log error ("DDNS: Error setting domain $Hostname.$Domain to IP $currentIP. $result->status")
} else={
    :log info "DDNS: Domain $Hostname.$Domain current IP $currentIP not changed. Not updated."
This does not depend on configuring the valid IP on a local interface, like in cases where the router access the internet thru another bridge.
Hi.
Is it possible, that GoDaddy changed something, because from 30.5. I get an error
Download from api.godaddy.com FAILED: Fetch failed with status 403
Is it only me or also others?
Same for me, just noticed it now
Reply from godaddy:
" Hi,
Thank you for reaching out to us regarding the recent changes to our Domain API.
We wanted to inform you that we have recently updated our Domain API requirements. As part of this update, customers are now required to have 50 or more domains in their account to utilize the API. Unfortunately, as you currently only have 1 domain in your account, access to the API is blocked for you.
However, we want to assure you that you still have access to the OTE API without any blocks.
We apologize for any confusion or inconvenience this may have caused. If you have any further questions or need assistance with any other aspect of our services, please don’t hesitate to reach out.
Thank you for your understanding.
Regards,
API Support Team"
