Good CCQ and Signal , Still high ping ( my isp says its the NOISE from my area!)
so i got a wireless internet from a local isp , but sometimes my DNS ping time goes as high as 300 ! but when everything is normal its around 2-3 ms.
my ccq is above 90% , and signal Strength is around -60 and Signal To Noise 40 db
also the frequency that im using has a very low usage , and i changed to other low usage frequencies and the problem didn’t solve( my bandwidth is empty when the ping time goes high and ping time to my access point and my radio is 1ms since im using a lan connection)
my isp says its because of the noise around the area that i live !!! but wouldn’t that effect ccq or signal Strength ? and when the ping time goes from 3 to 300 my CCQ or my signal Strength does not change !
so are they lying to me ? is there a problem with their routers or something ? or can it be actually the noise from my area ?
also my radio is mikrotik sextant g 5hpnd
PSA , when the DNS ping time goes from 3ms to 300ms , the signal strength , CCQ or signal to noise , non of them changes ! so it just goes from 3ms to 300ms all of the sudden without any change to any parameters !
and distance is 14km
Perhaps it would be better to call it “interference” vs “noise”. But yes, you can have poor QoS due to interference, and still see the radio stats you’re reporting. For example SNR is measured between received signal strength and average background noise level – but if interference is bursty (which it typically is) it will not factor in the average background noise level. Similarly, interference will have no impact on the RSSI. This is because when the signal is received, it is always received at the same level. Problem is : sometimes it is not received! (due to interference drowning it out).
Thanks for the reply!
can you simplify what you just said ? because i dont have much education about wireless stuff
so this QoS that you are saying , can i see it in my winbox ? is there anyway that i can be sure what is causing the problem ? i just wanna make sure its not a problem with the ISP ( shouldn’t them be able to fix the problem ?)
can you explain more about this interference ?! is it same as Frequency usage in WinBox ?
also i spoke with a wireless expert , and he said i should get the ip address of the radio that i’m connecting to (radio of the ISP) and then go the Bandwidth Test (in Winbox) and then type IP address and see if the link is ok ( he didn’t explain what is considered OK and what should i do in there ) if it was ok then the problem is not the noise and its the ISP , but i could not see the Radio IP address in the Winbox neighbors since the isp does not allow customers to see the IP address of their radio , and they didn’t give the ip to me , my question what is this bandwidth test and why they are not giving the IP address of their radio to me ?!
and my last question is , how can i fix this problem ?! is there any hope ?!
PSA. distance is 14km , not 2km
Do a test:
Start an FTP download from an internet server (preferably a big file). Make sure you download it though the IP address of the server.
For example: ftp://48.25.26.145/pub/… (fill in the IP address of the correct FTP server).
Run it when everything is “fine”, when the DNS queries are 3 mSec.
note the speed, average.
Then run the same test when the DNS ping rises to 300. Do you still have the same speed?
Also, change the DNS servers to Google DNS: 8.8.8.8 and 8.8.4.4 or OpenDNS: 208.67.222.222
what do you mean by a FTP download ? i googled FTP download but didnt find any link like what you said
can you give me a link ?
but my overall average download speed goes from 800-900KB/s ( when 3ms ) to 200-500KB/s(when 200-300ms) and i used Internet Download Manager To calculate
also when you say change the DNS servers to 8.8.8.8 , you mean i should change both the prefered dns server and alternative DNS server to 8.8.8.8 ?
also i posted this somewhere else and someone replied with this :
Since you are in an open frequency you can’t count on you getting data across the links every single time so the ping time increases as the retry occurs.
is he right ? is this a normal thing ?
Correct. The IP for the FTP server is an example.
this is a real one:
ftp://194.109.21.27/pub/test. There you will find a dummy file of 100 Mb or 1 Gb.
And yes, the DNS can be primary and secondary.
so i tired that and the result was same as before , went from 800KB/s to 400KB/s when the ping raise up
also changing the DNS to that made the ping time even go higher sometimes so i had to put it back to default
also someone said this on another forum :
is this guy right ? this problem is a normal thing with wireless internet and has nothing to do with ISP ?!
Yes, he “can” be right. To investigate it will require a lot of effort, regarding finding out the “interferer”, and even then, if you found it, what are you going to do about the guy (or woman) who messes up your link…
Solutions:
  1. Switch to 5 GHz. both ends should support it (the LHG is pretty cheap, 59$ per unit (you need two of them).
  2. Switch to a different channel. Both sides should do that.
  3. Use a more directive antenna, cover it with a dome if needed. But that might not work well, since the interference can also be at the ISP’s end.
but can you explain why if there is a “interferer” shouldn’t that effect the ccq or signal Strength or signal to noise ? i even tried a frequency with a low usage but it didn’t work , as you may already know i’m not an expert in wireless stuff and i just gathered some information from different sources so if you help me understand why this isn’t effecting any of these parameters that would be great
also what do you mean by switching to 5GHz and channel ? you mean Band and Channel Width in my wlan1 setting ?if so , my band is on 5GHz-A/N and channel width is 20MHz , should i change them ?
interference as an example: is when you talk to someone on the street, and there is some noise form cars, busses etc… When there is not too much, it is fine. When tere is a lot of car traffic, you should “shout” harder. And if you are in a disco or club, you really need to shout very very hard, and move your mouth close to the ear of your partner.
Well, you and your partner are the dishes of Mikrotik. The noise are other people.
Noise is always present, and you cannot avoid it. You can though make your signal so loud that the noise influence is minimized.
So OK, you are already on 5 GHz. Try to change the channel number. Not the bandwidth yet. The narrower the bandwidth the better for interference, but less throughput.
So do not change the channel width yet, but try different channels. 5 Ghz band has much more channels, and you will probably find a good one .
sorry if im asking too much i’m just trying to learn , but in your example , i can hear the noise right ? like in the street i can know that there is a noise coming from some where ( maybe not knowing the source , but at least knowing its because of noise)
but in my situation everything stays the same when that “noise” comes around , as i said my CCQ and Signal and Signal To Noise stays the same when ping time goes as high as 400ms , shouldn’t this noise effect something ? like shouldn’t that effect CCQ or something ?!
maybe i’m missing something ? like another parameter that i dont know of ? like so far i learned about CCQ , Signal strength , signal to noise , and frequency usage , is there something else ?
also when you said try different channels , how should i change channel ? like in wireless tab i should go to scanner tab and then search for another antenna or something ? because my isp has another "antenna " nearby but that one has another problem , when i download anything the CCQ goes from 80-90% to 20% and then i get disconnected from the internet! so its unusable
You can hear the noise. See the spectral scan from both ends and select the best frequency. Also use the dish antennas with side shielding to suppress the noise from the environment.
Let your isp to solve the problem for you. He should have the necessary experience and you can learn from him.
well i don’t think they are really good at solving problems because everytime i call them they are like “hmmm no its normal for a wireless internet to have 400ms even though CCQ and signal are GREAT!” and when i ask them why when my ping time goes from 3ms to 400 my CCQ or singal does not change they don’t answer !
what do you mean see the spectral scan ?
and i already selected the frequency with lowest usage , also what do you mean use side shielding for dish antennas ? i don’t use a dish antenna i just have a mikrotik radio , and i don’t have access to my ISP’s antennas
please answer this question , how can it be possible to go from 3 ms to 300-400ms ( DNS ping time ) without any change in CCQ (90%) and signal (-60) and signal to noise (40db) ?? ( without usage of bandwidth )
shouldn’t this noise effect something ? i also talked to a wireless expert(as he claimed to be ) and he said if there was a noise problem and overall a problem with the link , it should have effected the CCQ or at least something
Well, I agree with Jarda.
Let the ISP solve it. If they cannot, then they are not capable in doing this. Select a different one (probably they are the only one with “high speed” internet), so then you are stuck with them…
well the problem is i already spend money on that radio and they won’t give my money back :frowning: :frowning:
and there is no other ISP around my house !
so this is why i’m asking you guys to help me figure this out , because if this is not a noise problem and in fact it’s a problem with them then i might just sue them , but before i do that i need to make sure about what is causing this problem
and all i’m asking is to answer the question i asked above :
shouldn’t this noise effect something ? like dropping the CCQ ?? i also talked to a wireless expert(as he claimed to be ) and he said if there was a noise problem and overall a problem with the link , it should have effected the CCQ or at least something
also i need to state that i use the mikrotik’s console → tools > ping to calculate my dns’s ping time and this is a problem because when my dns ping time goes from 3 to 400 , then for example my google.com ping time goes from 80ms to 500-600 ms and so other websites too ! and download speed goes from 900KB/s to 300-200KB/s
PSA : i’m going to say again that i’m not an expert on wireless stuff and i gathered information from different places so if i’m missing something here please let me know ! any help would be appreciated!!!
You should isolate the problem first. Are you sure that the delay is on your last mile? Maybe it is somewhere in or behind the network of your isp. It’s always better for consumer to buy the service delivered to his ethernet port leaving all the technology on the isp. Then its not your business what is wrong with the connectivity… But its too late now. There is option to nicely negotiate with the isp to help you or to hire a local independent consultant to either help you to connect or to proove the origin of the problem. You cannot succeed with blind help over the discussion forum with this especially if you don’t have own experience.
but can you at least say that is it possible to be a noise problem even when the CCQ signal and frequency usage are ok ? and how can i know this “delay” is on my last mile?!
i mean all i’m asking is this : how can it be a NOISE problem if ping time goes from 3ms to 400ms without any change to CCQ ?
your answer can be as technical as you want but all i’m asking is this , is it possible or not ?
there is gotta be a way to at least locate the problem with the access i have , i know i don’t have access to isp antenna and stuff but i’m not even asking for a fix !!! all i’m asking is that someone with good knowledge of wireless connection and mikrotik radios to tell me something like " YES , even with 100% CCQ and best signal possible and a Frequency with lowest usage , it still can be because of the noise , because … (technical reason or personal experience or …) "
and i don’t know any local independent consultant! so my only hope is you guys since my isp won’t be trying to solve the problem anymore because they are sure its the noise !
Ok. There can be whatever. I told you to see spectral scan and to use side shielded antenna. May happen that it is badly aligned or there is noise on Ap side that makes your signal bad. Hard to say without local observation.
