All of a sudden, my usually OK network suddenly giving problems. Ping-ing is ok, normal speed and seldom time-outs, but browsing, say to http://www.yahoo.com, failed to load.
Not sure what to check. On the interface windows, there doesn’t seem to be unusual load.
Anybody has any idea on what I should monitor? I suspect there was some traffic, but I don’t know how to capture, let alone to proof it.
use netstat -a command on your computer to see where does your computer communicating with.
try ping using bigger size like 1000 maybe to check the connection.
try ping to ip and not site maybe you got problems on dns
can you ping yahoo.com or any dns from the router?
The dns can resolve url??
Maxi.
Hi All,
Yes, DNS resolved the IP, so no issue on DNS.
Bigger ping on yahoo also gives good ms.
