good signal but client can't connect, connect with low tx/xr
iam A WISP and i have tower , routerboard 333 with alfa minipci WPCI085H , antenna 12 dbi my cusotmer at this tower about 30 ,
so the problem is :
i have a good signal but some time my customer can’t connect
when they make site servey they see a good signal but their devices can’t connect just scaning
note : my client use edimax , tp-link
but when i reboot my routerboard they connect for 1 hour some times for 2 hours and the problem happened again
to go around this i make an other two virtual ap with two different names so when they can’t connect they try the virtual and this succeed
the other thing they always connect with just 1 or 2 mbps tx and 11 mbps rx
and really i have a bad through output
i try to use low tx-power and try to use the top-tx-power it is the same
and try with support rate no way the same problem
this is my wireless config
[xxxxx@OBM-NET] > interface wireless print
0 R name=“OBM-WAN” mtu=1500 mac-address=00:C0:CA:21:76:47 arp=enabled
interface-type=Atheros AR5413 mode=ap-bridge ssid=“OBM-NET”
frequency=2462 band=2.4ghz-b scan-list=default antenna-mode=ant-a
wds-mode=dynamic wds-default-bridge=WAN-LAN wds-ignore-ssid=no
default-authentication=yes default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
compression=no
1 R name=“OBM-WAN2” mtu=1500 mac-address=00:4F:62:24:64:18 arp=enabled
master-interface=OBM-WAN ssid=“OBM-NET2” wds-mode=dynamic
2 name=“OBM-WAN3” mtu=1500 mac-address=00:02:6F:53:E8:88 arp=enabled
master-interface=OBM-WAN ssid=“OBM-NET3” wds-mode=dynamic
so please help me with any comment any suggestion to solve this problem
you probably have to play around with the frequencies a bit 2.4GHz is the worst of the all; or replace some cards.
try setting the APs to B/G, in B only mode you can’t achieve more than 11m
move onto 5GHz, the kit price is almost the same and the freq is a bit more stable :slight_smile:
get away from edimax and tplink - cheap doesn’t mean good.
try UBNT Nanostations if you think MKTK based kit is too expensive for you.
steven
thank you for reply semakka
first of all i know that 2.4 ghz is the wrost one but here in my country i can’t use other freq. like 5ghz just here they allow 2.4ghz for ap mode and 5ghz for p2p
and i know b mode just 11 mbps i hope to have 11 m but in tx not only rx
i know edimax and tp-link are cheep but i can’t say to someone i can’t connect you becouse you have edimax or tp-link or any product
other places i have ap senao EOC-3220 and it is work fine but the problem just in my new routerboard
i have other Q. the maximam of alfa minipci is 1000mw is it butter to use manual tx-power and set it to the highest or what is the best selection
i try to search for tec. spec. to find how to put manual tx-power for this card but i did’t find any help
any one have any idea about manual tx-power table
thank you again
I have a similar problem. But in my case the AP TP-Link station can not connect to my RB411AH in WDS mode at any time. I have good signal but can not get any ping arrives Routerboard.
[admin@RB411] > int wireless pr
0 name=“RB411” mtu=1500 mac-address=00:15:6D:65:6E:10 arp=enabled
interface-type=Atheros AR5413 mode=ap-bridge ssid=“RB411”
frequency=2457 band=2.4ghz-b scan-list=default antenna-mode=ant-a
wds-mode=dynamic wds-default-bridge=bridge1 wds-ignore-ssid=no
default-client-tx-limit=0 hide-ssid=no security-profile=wep
compression=no
Suggestions?
